Stalling and Sputtering-1993 YJ 4.0 - JeepForum.com
post #1 of 8 Old 06-30-2013, 12:38 PM Thread Starter
weerwolv
Hi all,
Recently had a lot of fuel work done on my yj; replacement of fuel rail and cleaned injectors, etc.
Jeep ran great for three days and now have a problem.
Jeep has no problem starting and going to idle
When in neutral and I crank up the throttle to 2k or higher and come off throttle she stalls. Can't go to idle
When driving and switching gears (ax15) she sputters when I'm giving gas and I have to come off throttle a bit.
Any ideas what this could be? No codes showing
Thank in advance
weerwolv is offline
post #2 of 8 Old 06-30-2013, 01:21 PM Thread Starter
weerwolv
Hi all,
My mistake on codes as I just re-checked.
It;s throwing codes
12
21
24
weerwolv is offline
post #3 of 8 Old 06-30-2013, 05:14 PM
pete1991YJ
code 21 = oxygen sensor or circuit
code 24 = throttle position sensor or circuit
You may want to test both sensors separately, its not hard to do. I'm inclined to believe that it maybe a circuit issue because I seem to recall that they both share the same hot lead from the ECU. Don't quote me on that tho. Test the sensors separately first.
Whoops before I forget, make sure you have a good ground from the engine to the firewall or to the battery before you test any electrical. No point in testing with a bum ground throwing off your readings.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #4 of 8 Old 07-01-2013, 12:38 AM
VenomousMaximus
Try performing a Distributor Sync or Indexing... #1 piston TDC on compression stroke, the tip of the rotor in dizzy should be just past the terminal #1(just scribe a line on distributor itself center of tower #1) .020", if not, remove distributor to re*index it. You may have to modify distributor a little to turn.
VenomousMaximus is offline
post #5 of 8 Old 07-01-2013, 12:40 AM
VenomousMaximus
That's "tip of the rotor" f@*king auto correct! LOL
post #6 of 8 Old 07-01-2013, 12:47 AM
VenomousMaximus
More potential causes...
* camshaft position sensor
* crankshaft sensor
* defective PCM
* defective upstream O2 Sensor
* wiring harness / ground
* ignition coil
* MAP sensor
* TPS sensor
post #7 of 8 Old 07-01-2013, 12:56 AM
VenomousMaximus
The PCM on this engine allows the upstream O2 sensor signal to determine 25% of the fuel control... So if the O2 sensor voltage remains too high as the PCM moves to closed loop, the controller will take away fuel. Usually in this case the O2 sensor is shorted to voltage.
post #8 of 8 Old 07-01-2013, 09:18 AM Thread Starter
weerwolv
Thanks guys for the background and help. Just picked up a new TPS and 02 from Autozone and will try them tonight.
Gonna shoot for the TPS first. If that corrects things enough I'll return the 02. If not, 02 goes in next
-Chris
weerwolv is offline
