Stalling problems - JeepForum.com
post #1 of 7 Old 11-11-2004, 01:53 PM Thread Starter
soxfann
Stalling problems
I own a 89 Jeep Wrangler w/4.2L I6. She starts up fine, but after a minute or so, she stalls out. I've checked all the vacuum connections, replaced the fuel filter and alternator (alternator was bad). The carb is new (3-6 months old). Any ideas on what the problem might be?
soxfann is offline
post #2 of 7 Old 11-11-2004, 02:02 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
Is your idle set properly? Does she stall when the gas pedal is applied?
atomicmoose is offline
post #3 of 7 Old 11-11-2004, 02:04 PM Thread Starter
soxfann
Pressing the gas pedal is only way to keep it from stalling. I was thinking about setting the idle though.
soxfann is offline
post #4 of 7 Old 11-11-2004, 06:40 PM
mikenj73
mikenj73's Avatar
Is it the stock Carter carb or the Weber carb? If it is the Carter, I can relate to your problem. The only time mine didn't want to stall was when I first started up and the choke was on. My carb is not new like yours, but these are some things you might wanna check out or try.
Does the Jeep run better after it has warmed up? If so, check your choke setting.... sound like it is too lean.
Does it still run bad after it's warmed up? Then it might be your idle setting, as atomicmoose mentioned. It might be idling too low when the choke comes off. You'd need to turn the idle screw up until it runs smoothly
If that doesn't do it, then warm up the Jeep and then look down into the carb (with caution and safety glasses). See if there is any fuel dripping down into the throat of the carb. If there is, you might need to enlarge your idle tubes like I had to. They need to be drilled out to 0.032". You can get that size drill bit at a hobby store. Go to this address for the how-to:
http://forums.vmag.com/pm-0501/messages/2566.html
Check the idle mixture screws. I screwed mine all the way in, then I backed them out a little at a time until I got the smoothest idle.
When all else fails, use some carb cleaner, couldn't hurt. Hope this helps.
'88 YJ: 6 cyl, 5 spd, 142K
Modifications: None (keeping it running in stock form is expensive enough)
mikenj73 is offline
post #5 of 7 Old 11-13-2004, 02:03 PM Thread Starter
soxfann
I appreciate the help guys. However I think I've hit a snag. While tracing my vacuum lines I noticed one that leads from the vacuum solenoids to the sol-vac idle speed adjustment on the carb is just dangling (not connected). Actually I really don't think I have a sol-vac. The carb is the original carter, I mentioned I had it replaced and it is remanufactured. Is it possible for this piece to be missing all together? Or I am just missing it (not seeing it) all together.
I know what it looks like, but it isn't where it is supposed to be.
soxfann is offline
post #6 of 7 Old 11-13-2004, 10:32 PM
Burnunit22
A Weber will make all of those headaches go away....kinda like our David Ortiz made your sox headache go away!
Signed, Twins Guy
P.S. My 11 year old's main man was Dougie Minki-tinka-witz (has his autogragh and everything), so be nice to him!
'89 YJ Laredo
Mostly stock w/ rebuilt 258 and Weber 38
Burnunit22 is offline
post #7 of 7 Old 11-20-2004, 06:18 PM
Mazdaboy
Wow that's scary I have the exact same problem. I have a 1 year old reman Carter carb with the one vacuum line dangling. Its been dangling all year I think. My Jeep runs fine when above 1100 rpms, but dies when I go below that. I am considering the weber upgrade and am hoping this will fix it.
MB
89 w/1975 258. TF999 Automatic. Weber K551 38. BDS 2" lift. 15 in RockCrawlers w/31" Bridgestone Dueler REVO's. Smittybilt stereo security console. Alpine mp3 cd player. BMW steering wheel. 4.0 head conversion. Heavy duty bumpers. Deka Intimidator battery.
Mazdaboy is offline
YJ 4.2 engine stalling problems HELP PLEASE mark268 YJ Wrangler Technical Forum 4 06-18-2007 10:59 AM
4.2 problems after stalling in water... dbikers YJ Wrangler Technical Forum 1 06-17-2007 06:19 PM
Stalling problems 4wheeler98 TJ Wrangler Technical Forum 6 03-14-2007 11:43 PM
jeep having stalling problems dragonjeep TJ Wrangler Technical Forum 4 05-07-2005 12:48 PM
Stalling problems in 88 PhoenixEML YJ Wrangler Technical Forum 32 04-11-2005 02:19 PM
