Stalling problem after warm up - JeepForum.com
post #1 of 26 Old 06-02-2013, 01:00 AM Thread Starter
diaz425
my jeep just started stalling after warm up. at first i thought i ran out of fuel. after a min i would start her and she would start fine than dies. i had to get it towed to my house. the next day on a cold start i started her up with no problems after about 10 mins warming up it stalls. than i started again than stalls 2 mins later. what is causing the problem. i returned the 6 months old fuel pump and got a new one just in case that was the problem (still under warranty. haven't install yet. rainy day).
btw i just bought new coil. not yet install (it's 2am)
any other ideas??
diaz425 is offline
post #2 of 26 Old 06-02-2013, 07:09 AM
Old4X
1990 CJ7
Is it rich or lean running when it stalls?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 26 Old 06-02-2013, 07:17 AM
EABiker
Is it showing any codes? If it runs cold and not warmed up, that most likely means a sensor has gone bad. When cold, the ECU controls the engine by using a fixed set of curves, (open loop). When the engine reaches operating temperature, the ECU monitors the inputs from the sensors, and adjust the fuel and timing accordingly, (closed loop). If one of the sensors has gone bad...well you know the saying, "garbage in, garbage out".
EABiker is offline
post #4 of 26 Old 06-02-2013, 04:26 PM
Que89YJ
Disconnect your O2 sensor and see if it still does it. O2 or engine temp sensor.
Que89YJ is offline
post #5 of 26 Old 06-02-2013, 05:41 PM Thread Starter
diaz425
Forgot to mention. When it is about to stall it bogs like if i ran out of gas.
diaz425 is offline
post #6 of 26 Old 06-02-2013, 07:41 PM
Old4X
1990 CJ7
What do your plugs look like?
Old4X is offline
post #7 of 26 Old 06-03-2013, 07:07 AM
UZI4U
Run it and let it get warm. If the head pipe before the cat converter is too hot to touch and the pipe behind it is relatively cool, your cat converter is plugged.
MCLMM
UZI4U is offline
post #8 of 26 Old 06-03-2013, 04:12 PM Thread Starter
diaz425
i put on new fuel pump and coil. i also tighten the o2 sensor (was loose). after doing those i started her up and notice the rpm needle acting up just before the car stalled.
i will try what UZI4U said about the cat. cant do it now gotta go to work
diaz425 is offline
post #9 of 26 Old 06-03-2013, 04:24 PM Thread Starter
diaz425
i started her up right now ran great than dies out (as if i shut her off).
I read somewhere in here about ICM. Where is the ICM located at?
here is the where i found out about the ICM http://www.jeepforum.com/forum/f12/h...le-bad-663378/
diaz425 is offline
post #10 of 26 Old 06-03-2013, 06:44 PM
Old4X
1990 CJ7
The ICM is under the washer bottle
Old4X is offline
post #11 of 26 Old 06-03-2013, 06:47 PM
flcracker
That is the ecm, I think the icm is in the distributor
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #12 of 26 Old 06-03-2013, 08:06 PM
Old4X
1990 CJ7
4.2 ICM is under the washer bottle like I said. Look it up on the maint manual
Old4X is offline
post #13 of 26 Old 06-03-2013, 08:17 PM
flcracker
Crap, sorry, spoke too soon... that is where the ecm is on mine.... note to self: don't open mouth before engaging brain...
post #14 of 26 Old 06-03-2013, 09:14 PM
Que89YJ
icm is the coil with the plug wire running to the distributor.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #15 of 26 Old 06-03-2013, 09:14 PM
Que89YJ
ignition coil module
Fault codes:
No Start:
Que89YJ is offline
