Stalling issue with Heavy Smoke - JeepForum.com
post #1 of 3 Old 05-18-2012, 10:59 PM Thread Starter
mbfshs2004
I have a 93 Grand Cherokee with a 5.2 I am having an issue with it after it gets warmed up 10 mins down the road with it smoking and when I give it gas it revs up but when I take my foot off the gas (ie stop light) the rpm drops way down, some time stalling, then on its own picks back up to where it should be then back down repeating a few time till it stalls out or levels out at normal. The smoke is clearly inside the engine because if I open the oil fill spot there is smoke inside. Also the temp will run fine for a bit but then begins to climb.
mbfshs2004 is offline
post #2 of 3 Old 05-18-2012, 11:50 PM
Modstock
Do a compresion test. If that checks out good at least you know its not the rings.
Modstock is offline
post #3 of 3 Old 05-19-2012, 05:31 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I'm confused. Is the exhaust smoking or are you seeing the oil vapor in the heads?
Check for a blown plenum gasket, compression and leak down test, and start checking sensors.
ratmonkey is offline
hot , idle , oil , smoke , stall
Stalling issue on '06 TJ officerbrando TJ Wrangler Technical Forum 1 03-24-2012 10:11 PM
Heavy bumper and winch creating issue... f6Fireball TJ Wrangler Technical Forum 3 03-19-2011 04:43 PM
Smoke out of PCV. Stalling. Smell gas. kylelikewhoa YJ Wrangler Technical Forum 8 09-17-2009 07:04 PM
HEAVY SMOKE... Seized brake caliper? martells2 YJ Wrangler Technical Forum 9 01-04-2007 02:41 PM
97 TJ stalling around heavy turns with 1/4 tank of gas? skyjacked94xj TJ Wrangler Technical Forum 14 02-01-2006 09:44 PM
