stall and restart - JeepForum.com
post #1 of 10 Old 12-22-2013, 07:22 PM Thread Starter
rdrobish3
stall and restart
Yesterday I somehow managed to stall my 95 yj 2.5l 5-speed. When I went to restart it, it just kept cranking until the battery was almost dead and it finally started, does anyone have any idea what the problem may be? Any help would be great thanks
rdrobish3 is offline
post #2 of 10 Old 12-25-2013, 11:30 PM
theflyer007
Was it cold? Mine does this if I don't warm it up when its cold outside.
theflyer007 is offline
post #3 of 10 Old 12-26-2013, 07:38 AM
pete1991YJ
X2 if it was cold, and it has been cold lately... BTW welcome to Jeep Forum, you've just found one of the best Jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #4 of 10 Old 12-26-2013, 10:42 PM Thread Starter
rdrobish3
It was cold out but it had been running for almost 30 minutes its done this before but never this bad
post #5 of 10 Old 12-26-2013, 10:43 PM Thread Starter
rdrobish3
And thank you for the welcome I've used this forum on my computer a couple times in the past and it has been excellent with helpful information
post #6 of 10 Old 12-27-2013, 06:02 AM
pete1991YJ
Hrm, it was warmed up a bit? That changes things a bit.. the only suggestions I can think of for now is, get the computer codes just in case, and maybe try cleaning the IAC (idle air control). This video shows you how to get any error codes from the computder, its easy and free with no special tools :
As far as the IAC goes, its ust a couple of bolts on the throttle body and clean it out good with something like a toothbrush and some carb cleaner. Chances are good that you will have to remove the throttle body to get it off tho. Hope that helps.
post #7 of 10 Old 12-27-2013, 03:24 PM Thread Starter
rdrobish3
Ok I will try that and let you know thank you for all the help
post #8 of 10 Old 01-31-2014, 12:08 AM Thread Starter
rdrobish3
It ended up being linked to my thermostat I've replaced that and everything is fine now thanks for all the help
post #9 of 10 Old 01-31-2014, 09:00 AM
Siva283
You may have a short in the temp sensor on the tstat housing. Its the one the ECM uses(Gauge sensor is in the back of the head) This sensor can cause no starts when it is bad. Next time it does it after a few cranks push the pedal to the floor and try starting it. It tells it there is a flood condition and shuts off the injectors to clear it. That should lean it out enough to start.
Ask me how I know...
Siva283 is offline
post #10 of 10 Old 01-31-2014, 04:35 PM
booboowv77
x2
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
