Stainless Fasteners.....? - JeepForum.com
post #1 of 12 Old 09-17-2012, 10:32 AM Thread Starter
youngjeeper11
youngjeeper11's Avatar
1987 YJ Wrangler
So I am very slowly re-building my Jeep, and since I have pieced it together from a few YJs, I am missing many body bolts, the 5/16-18 bolts that are used all over.
Anyway I am planning on buying new bolts that are hex head 18-8 Stainless Steel. It is not the best SS, (not 316) but they are just body bolts. I am just trying to avoid rust/siezing.
I am want to replace all the torx bolts with these as well.
We use Stainless fasteners all the time where I work (high pressure compressor company)
I do not see any issues with the stainless fasteners on my YJ, but I just wanted to throw it out there and see if anyone could think of any issues I might run into.
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college
Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project
Interned at Novak Conversions 2 summers ago
Ask me about my 4BT Cummins Motor Mounts!!
youngjeeper11 is offline
post #2 of 12 Old 09-17-2012, 10:49 AM
bogleparsons
I have have been replacing various bolts with stainless over the last couple years. No problems to date.
You probably know that grade 8 steel should be used in high stress or safety concern areas.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #3 of 12 Old 09-17-2012, 11:07 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Sounds good
Yea, body bolts do not see much stress, at least I hope not haha.
post #4 of 12 Old 09-17-2012, 11:23 AM
Que89YJ
No, you do not want to use stainless bolts or any of the stainless hardware that can see stress. Stainless is way too soft and while it is good that it doesnt rust most common stainless bolts are about a grade 2. They will snap with any torque you apply to them. It really is just not worth breaking one off. At least go grade 5 so if you need to use leverage on a stuck bolt it won't end with you drilling and tapping it.
Que89YJ is offline
post #5 of 12 Old 09-17-2012, 12:00 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
Well, what we have found here is that the use of a good anti-sieze, and if need be, a torque wrench, eliminates any of those issues.
We commonly had the same issue you speak of, but with anti-sieze, it virtually eliminated all accidental cross threading and/or removal problems.
post #6 of 12 Old 09-17-2012, 12:08 PM
Jeepsr4me
I just got done looking at a bolt site. And stainless fasteners are not nearly as strong as the steel counter part.
I like the cadium plated bolts.
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
Jeepsr4me is offline
post #7 of 12 Old 09-17-2012, 12:36 PM
Que89YJ
The Jeep came with grade 3 and 5. By using the common stainless bolts you are using grade 2. Also while you do torque them the dirt, body rolling and torquing will bind them up tighter then the spec.
I use grade 8's because when push comes to shove I know that when I put them in I will be able to get them back out in one piece. I seriously would have my reservations about SS on bolts.
Que89YJ is offline
post #8 of 12 Old 09-17-2012, 01:07 PM Thread Starter
youngjeeper11
1987 YJ Wrangler
if you look at that chart, it says:
Grade 5: min yield: 92ksi min tensile: 120ksi
18-8 SS (typical): min yield: 80-90 ksi min tensile: 100-125ksi....
Does not seem like much of a difference to me.... I was plannig on using 18-8, not really sure what the "typical" means though.
wheres my machinery's handbook.....
post #9 of 12 Old 09-17-2012, 02:10 PM
Jeepsr4me
A grade 8 bolt even rusted in can handle some serious torque and heat if needed to get out. The SS ones will gall up and fight ya.
But if i had access to some cheap SS bolts I would use them on every thing but winch mounting bolts and suspension bolts. As they are plenty strong and I normally dont like removing stuff once its put on,.
I bought a old military truck once, and it had a box of titanium bolts and nuts in it,. Talk about tough...
post #10 of 12 Old 09-17-2012, 08:22 PM
1SASjeepster
Youngjeeper,
I am not sure where that chart came from but I doubt it is accurate. ARP (Automotive Racing Products) created one of the most professional, if not THE PROFESSIONAL, company for fasteners in the world. They are simply the best and 95% of all professional racers use their bolts for all stress applications. They are the best and they make the best. They are the only people I know that make a super tough stainless steel bolt that is equal to Grade 8. They are costly but they are tough. If someone is saying that their stainless steel bolts are equal to Grade 8 THEN IT BETTER BE A.R.P. You should go to their website or ask them for a catalog. They have so much "engineering information for the non-engineer" that you would be amazed. You could learn more about bolts and fasteners than you ever imagined and it won't cost you anything.
Personally, I use Grade 8 with anti-sieze for all my high-stress applications, especially jeep suspension fasteners. On engines, if I can, I use A.R.P. studs. They work!!
I wish you the best, but I will really warn you about going with stainless bolts for roll bars, suspensions, etc. unless it is A.R.P. And no, I don't have stock in A.R.P. You need money to buy stock and I am broke. You got some great information and advice up there and I wish you the best.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #11 of 12 Old 09-18-2012, 10:19 AM Thread Starter
youngjeeper11
1987 YJ Wrangler
Thanks for the info!
I will check out ARPs website. However, like you said, they make bolts for racing and super high stress, all the guys in the diesel pick up truck world use only ARP head studs, but come on, I am talking jeep body bolts!
It is no doubt I would use grade 8 on winchs/supspension/roll cage/engine applications, but this is body bolts.
I am going to give the 18-8 SS bolts a shot with a ton of anti sieze.
I will be the first one to admit defeat on the first bolt head I twist off haha, then I will just have to go with titanium haha.
post #12 of 12 Old 09-18-2012, 04:37 PM
jdubsjeep
Stick with the grade 8 bolts on stress points and if you want to jazz up the misc. dash and assorted body bolts check out the pan head ss. They really clean up the overall look, if that is what you are looking for.
jdubsjeep is offline
Hitch Fasteners Yodwinder TJ Wrangler Technical Forum 2 11-17-2010 10:23 PM
soft top fasteners rice418 Wrangler General Discussion 3 05-11-2009 10:49 AM
stainless or black stainless spillz TJ Wrangler Technical Forum 20 03-23-2007 12:07 AM
Hard top Fasteners briant10 TJ Wrangler Technical Forum 15 07-21-2006 01:01 PM
Flare fasteners ? Torquemeister TJ Wrangler Technical Forum 5 11-11-2005 08:34 PM
