Squealing while driving, turning wheel, acceleration - JeepForum.com
post #1 of 6 Old 11-20-2008, 01:21 PM Thread Starter
gracemely
Hello,
I know the topic has been discussed elsewhere but I'd like to focus in on a specific set of circustances that cause my '91 YJ to make a squeal noise.
There was no problems coming to work thing morning. I left the lights on fore about 2 hours before a coworker told me about it. I went out, turned the lights off and turned the engine on. After 20 seconds or so I turned it off and went back inside (it's 30* outside).
About an hour later I went to lunch. When I put the Jeep in reverse and pressed the accelerator the squealing began (I stopped moving), when I turned the wheel left or right the squealing began again (I set the wheel straight), and lastly when I revved the engine the squealing began (If I hold the accelerator for a 40 seconds or so the squealing subsides and my RPM's increase by about 500). I drove around for about 10 minutes but the noise was still there.
Given these symptoms, are there any other answers besides what's been posted before?
Thanks guys!
G
-|91YJ|-
[]=o=[]
keep wavin'
gracemely is offline
post #2 of 6 Old 11-20-2008, 01:31 PM
CheapSunglasses
2007 XK Commander
It sounds to me like a loose belt or your power steering pump....Check the PS fluid and if it's low, top it off....You may need to bleed some air out of the PS system....Here's the link I used.
http://64.233.169.132/search?q=cache...lnk&cd=1&gl=us
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #3 of 6 Old 11-20-2008, 01:47 PM
hawaii
It's your PS assembly most likely if it happens when turning. I have a YJ box and an XJ pump on my TJ. It does it, no big deal.
hawaii is offline
post #4 of 6 Old 11-20-2008, 02:04 PM Thread Starter
gracemely
Just went out there and the fluid is indeed low (so is the temperature). The mounting bolt on the reservoir is also missing so I'll stop at Waly-world and let you know how things turn out.
-|91YJ|-
[]=o=[]
keep wavin'
post #5 of 6 Old 11-21-2008, 10:12 AM Thread Starter
gracemely
Worked. New bolt and PS fluid.
-|91YJ|-
[]=o=[]
keep wavin'
post #6 of 6 Old 11-21-2008, 01:09 PM
CheapSunglasses
2007 XK Commander
Glad to see you fixed the problem.
Squealing tires when turning. Vertisce JK Wrangler Technical Forum 2 09-26-2009 02:02 PM
squealing/ grinding sound when driving, please help dynastynut TJ Wrangler Technical Forum 7 08-28-2009 02:04 AM
Squealing belt is driving me crazy!! bmgadg YJ Wrangler Technical Forum 15 05-29-2009 09:18 AM
Steering wheel squealing Opi TJ Wrangler Technical Forum 6 03-06-2005 06:45 PM
Squealing/squeaking while driving? 2001 4.0 Sahara Paulis TJ Wrangler Technical Forum 5 08-13-2004 09:08 PM
