Squeaky front end. Driving me nuts! D: - JeepForum.com
post #1 of 12 Old 04-10-2013, 04:09 PM Thread Starter
Shoelessboi
So lately i noticed a front end squeak. Only when the jeeps moving. Im not sure which its coming from. Front left or right. I thought it was my ujoints on my driveshaft. But i pulled that and still squeaking. It only does it when the jeeps rolling. I checked the axle ujoint for play. Nothing. Before i just drop cash into it. Any ideas? Im leaning with wheel bearings?
Note : It started a day or two after it was stuck in a swamp overnight.
Originally Posted by dillonjm View Post
:The fact you even asked this question makes me want to punch myself in the face.
1991 Jeep Yj. 4cyl. 33x13.50x15 TSL Thornbirds, Super Wader Snorkel, 4" Rough Country Suspension Lift, Uniden Pro520xl Cb, 1000W Amp, 12" Rockford Fosgate P2 Sub.
Shoelessboi is offline
post #2 of 12 Old 04-10-2013, 04:17 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Worn front brakes?
GET OFF MY LAWN!
Chrisnvegas is online now
post #3 of 12 Old 04-10-2013, 04:36 PM Thread Starter
Shoelessboi
Originally Posted by Chrisnvegas View Post
Worn front brakes?
Its all practically new.
post #4 of 12 Old 04-10-2013, 05:20 PM
CHL
Sounds like something needs cleaned out. Ya know, from the night in the swamp.
Thanks,
Greg
CHL is offline
post #5 of 12 Old 04-10-2013, 05:35 PM Thread Starter
Shoelessboi
I pressure washed it. It sounds like front passenger side.
post #6 of 12 Old 04-10-2013, 06:55 PM
redblur
Squeaking suggests metal-to-metal contact somewhere.
You could try process of elimination by hitting one component of the suspension/steering system with a quick blast of WD-40 a day. For instance, the first day try the front left forward leaf spring bushing, wait for the WD-40 to evaporate or wash it off, listen for a squeak, and move on to the next component/bushing/ball joint/etc, Until the issue is found.
Also, take a grease gun to all the zerk's on the front suspension. That might eliminate a few possibilities.
1989 YJ with '92 4.0L, '91 AX-15, NP231 w/ JB SYE, 5" lift, 33's, Warn M8000, Olympic bumpers
redblur is offline
post #7 of 12 Old 04-10-2013, 07:08 PM Thread Starter
Shoelessboi
Did the grease gun. It only does it when its rolling. So its drivetrain somehow
post #8 of 12 Old 04-10-2013, 08:02 PM
Sparrows
Did you take your tire's off and spray out the hub/disk/caliper/knuckle/etc? I've had squeaking happen after I got debris trapped in those places that I couldn't get to without taking off the tire.
Just a thought.
Jack it up and jiggle the hell out of everything, see if you can recreate the noise while under/around it.
Cheers
June '13 YJOTM
Sparrows is offline
post #9 of 12 Old 04-10-2013, 08:11 PM
ROWA
ROWA's Avatar
Check for mud between the brake rotor and the dust shield, if it only squeakes when you cycle your supension check the bushings on the swaybar.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #10 of 12 Old 04-11-2013, 01:34 AM Thread Starter
Shoelessboi
Just a thought.
Cheers
No but i will see if i can do that tomorrow.
post #11 of 12 Old 04-11-2013, 01:34 AM Thread Starter
Shoelessboi
Id check the swaybar but its in my room :P
post #12 of 12 Old 04-11-2013, 09:17 AM
Siva283
Check your body mounts. There is metal to metal contact there. As the bushing wear or rot they can cause this. It would only happen while moving as well.
Ask me how I know...
Siva283 is offline
