squeaks & lifts - JeepForum.com
post #1 of 2 Old 09-23-2001, 11:34 PM Thread Starter
walt2810
squeaks & lifts
I have a 95 Sahara with a 3in lift since 98. Now I have lots of squeaks in the jeep, is there a fix? grease points? thanks
walt2810 is offline
post #2 of 2 Old 09-24-2001, 10:02 AM
osburn
osburn's Avatar
If you're using urethane bushings, then yeah grease will help. Open up the shackles a bit and smear some on that surface. Usually smearing the bushings with grease before installation helps a lot.
Another cause of squeaking suspension is u-bolts. If they get the slightest bit loose, they tend to squeak.
Matt Osburn
Score 1032
osburn is offline
Squeaks?! MusicMaverick TJ Wrangler Technical Forum 13 02-23-2008 09:29 PM
Squeaks and Rattles MusicMaverick TJ Wrangler Technical Forum 2 01-03-2008 11:53 AM
I got the squeaks Jakemd98 TJ Wrangler Technical Forum 6 03-05-2007 01:56 PM
I still have the squeaks??? help.. please.. Goondock TJ Wrangler Technical Forum 3 02-13-2007 10:41 AM
Wheel squeaks! gamecockjeeper TJ Wrangler Technical Forum 2 12-12-2005 10:29 PM
