Squeaking Noise coming from under the hood when started up - JeepForum.com
post #1 of 12 Old 10-24-2004, 10:32 PM Thread Starter
Squall280
As soon as I start my jeep I get an extemely loud squeaking noise from under the hood that won't go away until I lay on the gas. How do I get rid of this noise?
Squall280 is offline
post #2 of 12 Old 10-24-2004, 10:41 PM
jeepin_coug
It's a loose belt. Jeeps only have a serpentine belt, tighten it or replace it and the noise should go away.
jeepin_coug is offline
post #3 of 12 Old 10-25-2004, 07:06 AM
Why J?
Why J?'s Avatar
my 90 2.5l doesn't have a serpentine belt.
Why J? is offline
post #4 of 12 Old 10-25-2004, 10:15 AM
jeverett
My 87 4.2 does, but it seems to be Vbelts or serpentines with no reason or ascertainable pattern as to which year/model had which.
However I do agree it it is a loose belt, tighten and it should be fine. However before you tighten look for signs or wear or cracking, it may be stretched out enough that you need to replace. Also don't tighten it to much or you could ruin the bearings in your acc. that drive off of it.
04 TJ sport 4.0 automatic. Stock, for now.
jeverett is offline
post #5 of 12 Old 10-25-2004, 10:19 AM
farmboy1976
1987 YJ Wrangler
Three Words for you.
Permatex belt dressing!!
It's the bomb. And cheaper the replacing your belts.
Hope this helps, here is a link.
http://www.permatex.com/heavy_duty/E...&item_no=80073
Farmboy1976 (1987 Wrangler)
3.5 inch 4wd Suspension lift, 33 x12.5 BF's
Replaces items since purchase: Tires, Top, Radiator, Starter, Slave Cylinder(twice), Clutch Master Cylinder, Lots of hoses, Ring Gear, Clutch, Rebuilt Starter, Water Temp Gauge, MC2150 carb, nutter bypass, Electric choke, TFI Distributor, replaced power steering box, Smittybilt front seats
farmboy1976 is offline
post #6 of 12 Old 10-25-2004, 10:58 AM
JJorda
Jeep. Jeep? Jeep! Jeep.
JJorda's Avatar
From what I read, 91 and up models all had a serpentine belt, as well as the earlier California models. The 87-90 non-California models had V-belts. But yeah, it's either a belt problem or something's up with whatever the belt is turning. Take the belt off, try turning each pulley by hand, see if anything feels funky. If the belt looks cracked or glazed, replace the belt. See if the problem goes away.
1989 Jeep Wrangler - Daily Driver and project - Red Jeep Club #216, NRA Jeep Club #5
1967 Chevelle SS396 - Main Project <--454, TH400, 4.10's, FAST
1982 Caprice Classic - Another project <-- 350/700R4, 4 wheel discs
1979 Honda Civic CVCC - Yet another project <--goal of 60 mpg
JJorda is offline
post #7 of 12 Old 10-25-2004, 12:45 PM
Robbins
Cheaper than permatex belt dressing: A bar of soap. Seriously....with the engine running, carefully hold a bar of soap against the moving belt (if you loose a finger I didn't tell you to do that) on the side that contacts the pullies of course (or both sides on a serpentine) Bingo, no squeaky.
Bhudda walks up to a hot dog stand and he says "make me one with everything..."
Robbins is offline
post #8 of 12 Old 10-25-2004, 12:47 PM
JKNIPE2000
JKNIPE2000's Avatar
that would be somewhat safe if you removed the fan and got your engine to idle at about..say 60RPM lol...other than that i wouldnt attempt it while running...
Gone but not Forgotten:
1990 Islander O.D. Green
Currently no Jeep, but I'm in the market
JKNIPE2000 is offline
post #9 of 12 Old 10-25-2004, 12:53 PM
Robbins
I guess you could do it with the engine off if you just rubbed it down with the soap and then turned the engine over to expose the parts of the belt you couldn't reach... but the point is it really works. I've done it successfully with the engine running without losing any body parts, but not on a jeep...might be hard to reach in certain vehicles.
Robbins is offline
post #10 of 12 Old 10-25-2004, 02:28 PM
AFjeep
a cheap can of STP belt dressing worked on my jeep and nissan. no squeaks since I used a couple of months ago.
95 YJ, 2.5L, flowmaster exhaust, pretty much stock. Future upgrades; 2.5" RE lift, 31" tires, Posi-Lock, cheap winch. Anyone wishing to donate funds, please PM me!
AFjeep is offline
post #11 of 12 Old 10-25-2004, 04:15 PM Thread Starter
Squall280
for some reason t only does it when its cold out. any difference?
post #12 of 12 Old 10-25-2004, 04:28 PM
Robbins
Don't think so...only difference would be the expansion/contraction of the belt due to temp that would make it slightly tighter when it's cold...probably just enough to make it squeak when a little bit either way would make it stop... or it slides easier on cold pullies maybe? Whatever is causing it, from your description it's absolutely the belt and any of the above remedies should help.
Robbins is offline
Squeaking noise coming from under jeep. LeeGro TJ Wrangler Technical Forum 2 01-28-2010 01:11 PM
Squeaking from under hood plz help. NHWrangler TJ Wrangler Technical Forum 27 01-13-2010 12:47 AM
Squeaking noise coming from my clutch pedal...WTF?! end JK Wrangler Technical Forum 10 01-02-2009 05:23 PM
Funny Noise Under Hood..coming Out Of Egr Valve Chirping bcameron1974 YJ Wrangler Technical Forum 0 12-25-2008 12:17 PM
Squeaking noise coming from front... BWFBezerk TJ Wrangler Technical Forum 5 08-27-2008 10:13 PM
