Squeaking Drums? - JeepForum.com
post #1 of 5 Old 05-05-2010, 10:51 PM Thread Starter
cubewhiz
Squeaking Drums?
When I remove the drum, there is no squeak when the wheel is turning, but when I put the drum on, it is a constant squeak if the wheel is moving (even by hand). It came on kind of suddenly. I imagine somehow the brake pads are now rubbing on the inside of the drum? Any ideas?
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #2 of 5 Old 05-06-2010, 07:23 AM
MJMPC
Check your brake backingplate see if it is rubbing the drum.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 5 Old 05-06-2010, 07:35 AM
photoboy74
Drum problems can come from a variety of places. The adjuster screw may need to be turned in some, a spring could have come off, or you could have a failing brake cylinder.
Here's a diagram of a brake drum for comparison.
HowStuffWorks "How Drum Brakes Work"
photoboy74 is offline
post #4 of 5 Old 05-06-2010, 08:20 AM
Louie4
Have you adjusted the drums properly?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #5 of 5 Old 05-06-2010, 02:30 PM Thread Starter
cubewhiz
i adjusted them a few months ago with a brake spoon after I reinstalled the parking brake and replaced all the hardware. The cylinders were replaced in August, so they shouldn't be failing already.
cubewhiz is offline
Drums will not come off rompinthewoods YJ Wrangler Technical Forum 20 12-17-2008 08:27 AM
8.8 drums motorhead0320 YJ Wrangler Technical Forum 26 11-08-2007 05:21 PM
Drums Rollin TJ Wrangler Technical Forum 2 08-08-2007 10:30 PM
How do i Know when its time for new drums Marn TJ Wrangler Technical Forum 8 06-20-2007 02:28 PM
pic of drums tuckinauster YJ Wrangler Technical Forum 4 04-10-2007 11:14 PM
