Squeak coming from left front wheel - JeepForum.com
post #1 of 7 Old 04-21-2010, 02:07 PM Thread Starter
Jay_NH92
Every time I go over a bump even if its the slightest dip in the road I hear a squeaking noise coming from my left front wheel. I thought it might of been the shock not tightened down enough since i replaced them recently but that didn't seem to fix it. Any thoughts?
Black 92YJ 4.0 5 speed
Jay_NH92 is offline
post #2 of 7 Old 04-21-2010, 03:18 PM
disarm6565
If the squeak matches the speed of the tire, its most like your hub assembly. Take the tire off and see if there is any play in there.
1993 4.0 AX-15
disarm6565 is offline
post #3 of 7 Old 04-21-2010, 08:59 PM
alext1399
probably front hub bearing (wheel bearing)
alext1399 is offline
post #4 of 7 Old 04-21-2010, 09:05 PM
MoparFreak69
If its just a quick squeak as the suspension moves it could be shock or spring bushings squeaking a bit. Try shooting them with wd40 real quick and see if it goes away. Doesnt cost but a couple $$$ for a can (should have one around anyway) and if it doesnt help it wont hurt.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #5 of 7 Old 04-22-2010, 02:19 PM Thread Starter
Jay_NH92
I'm doing my axle seal this weekend on that same wheel so while its off ill see if anything is out of the ordinary.
Jay_NH92 is offline
post #6 of 7 Old 04-22-2010, 05:44 PM
Axl Jack
Do you still have those dust shields on your front axle? It is possible that one is rubbing slightly on the rotor if its bent in a little.
FYI, I removed those dust shields long ago. They are mud collectors IMHO.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #7 of 7 Old 04-23-2010, 07:52 AM Thread Starter
Jay_NH92
Yeah there still on there. I just sprayed some wd-40 on the bushings for the shocks. The squeaking went away
Jay_NH92 is offline
Weird squeak coming from right front tire. Todd4a TJ Wrangler Technical Forum 8 03-04-2011 04:35 PM
High pitched squeak coming from front end NEWtoTHEjeepLIF TJ Wrangler Technical Forum 9 11-19-2009 09:01 AM
04 tj squeak coming from front ds or t case iteme1084 TJ Wrangler Technical Forum 4 10-20-2009 09:36 PM
Weird Vibration Coming from Front Left Tire/Wheel Catrone TJ Wrangler Technical Forum 3 03-03-2008 08:58 PM
hit a bump..now my front left wheel area has a squeaking coming from it sk80soarus YJ Wrangler Technical Forum 6 09-04-2006 10:11 PM
