Sputtering when i turn on any lights or heater - JeepForum.com
post #1 of 11 Old 10-24-2011, 12:53 AM Thread Starter
Jeremiahsharp
My yj wrangler runs fine during the day but when I turn my headlights on or blinkers or kcs or heater it starts to sputter and backfire I need help I guest I had the alternater and battery tested everything was good iam in the dark right now I do all my own work so as much detail would be nice thank you I just want it to run smooth again.
Jeremiahsharp is offline
post #2 of 11 Old 10-24-2011, 04:11 AM
sprngrider
Is this only happening at idle, or while driving down the road? Are you saying you dont use your blinkers during the day?
Hook up a voltmeter to the battery when you turn on an accessory, see what the output is. Should be between 10 and 14.
1994 2.5L WRANGLER S.
sprngrider is offline
post #3 of 11 Old 10-24-2011, 10:59 AM
Brown Dog
Vendor
Brown Dog's Avatar
I think you have a short to ground somewhere in the headlight circuit.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 11 Old 10-24-2011, 12:36 PM Thread Starter
Jeremiahsharp
Happens at an idle and driving I had the battery tested and I was Gunna pull the alternator out today to have it tested but idk the lights and everything work when the motor is off but when it's running it wants to die
post #5 of 11 Old 10-24-2011, 12:59 PM
Que89YJ
You are loading the alternator and it can't keep up. The stock alt. is 60 amps. If you are running KC's and other after markets you are asking too much of it. Look up the CS-144 alternator mod in the FAQ or search for it on line. It's a good mod to do and will take care of your issue.
Que89YJ is offline
post #6 of 11 Old 10-24-2011, 06:53 PM
nembudonna
A bad ground somewhere gets my vote also. It happens all the time.
nembudonna is offline
post #7 of 11 Old 10-24-2011, 09:15 PM Thread Starter
Jeremiahsharp
I went and bought a new alternator and now it holds a charge but it's still running rough I put new spark plugs in it as well then I looked at the air filter and it was covered in mud so new air filter and clean all the spark plug wires and cap and rotor look good idk why it's running so rough still any other ideas the headlights and kcs work I went with a 90 amp alternator so it has more pull
post #8 of 11 Old 10-24-2011, 10:27 PM
nembudonna
What the heck does idk mean. Wait, Maybe I don't want to know.
post #9 of 11 Old 10-24-2011, 11:10 PM
lclark2074
Ok first use a volt meter on the battrey set the volt meter on dc 20 volt scall . Turn the jeep on put the jeep in nutral then cheek the battrey. Then put the lites on check to see how much the volts drop. Next chang the scall to AC 20 volt scall . tell us what the numbers are. I got a cuppel of ideas what may make this hapen but do this first.
night crew 226
lclark2074 is offline
post #10 of 11 Old 10-24-2011, 11:20 PM
ptwhaler
I had to ask my kids that when I first started texting with my phone. Means 'I don't know'
"In wine there is truth
In beer there is strength
In water there is bacteria"
ptwhaler is offline
post #11 of 11 Old 10-24-2011, 11:37 PM
nembudonna
OH. You didn't know like I didn't know. I don't text. Hell, I don't even have a cell phone. I still have a rock tablet. You take care.
