sputtering missing flooding when in Drive - JeepForum.com
post #1 of 3 Old 05-20-2010, 04:43 PM Thread Starter
hazelnut
1987 YJ Wrangler
I recently had my TF999 automatic rebuilt, and now when I am in drive and accelerating, I have a bad miss, sputter, and flooding. It is not close to as bad if I shift it manually in 1st or 2nd, just when I leave it in Drive. I have the stock Carter with the nutter bypass. It did not have this issue before, but my tranny and tcase were just hanging on until I blew them up.
Any ideas where I should start? I already changed the plugs, rotor, dist cap, etc with no change.
hazelnut is offline
post #2 of 3 Old 05-20-2010, 06:44 PM
Missouribound
This all happened after the tranny rebuild? hmmmm. Probably a coincidence. I's check the fuel pump pressure and output, change the fuel filter, and check the return line to the tank.
Missouribound is offline
post #3 of 3 Old 05-20-2010, 06:56 PM
dtn8tr
First thing that I would do is toss the Carter out on the highway in front of a semi! Seriously though, I agree with Missouri that this sounds like more of a coincidence. There are a lot of threads on here about what to look for on the BBD. Check the fuel pressure and look to see if you have gas dripping in the carb. The sputter and flooding could be plugged venturi or a bad float. If you can find a Weber or Motorcraft 2100/2150 on craigslist or ebay, I'd snatch it up and change over the carb. I find the Weber easy to adjust and running the 38DGES on a stock motor I'm getting 17mpg with 31" tires.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
Engine Missing can start and drive a mile i it starts again bradpenton TJ Wrangler Technical Forum 3 06-28-2009 06:33 PM
89 YJ flooding itself out. Burmman YJ Wrangler Technical Forum 13 11-07-2008 07:03 PM
engine sputtering/missing under load - Need help...on the side of the freeway Jeebs YJ Wrangler Technical Forum 7 03-25-2008 10:42 PM
2.4 missing/sputtering terrible TJ Wrangler Technical Forum 5 11-02-2006 04:59 PM
Engine missing sputtering coughing, Help! Kemo YJ Wrangler Technical Forum 0 12-06-2005 04:13 PM
