Sputtering in low rpm - JeepForum.com
post #1 of 2 Old 03-09-2012, 10:11 PM Thread Starter
arthurromero
I have a 2.5L 4 cyl, I have recently replaced the head gasket due to milky oil. I have cleaned every inch on the engine i could during the tear down. Changed the spark plugs, wires, distributor cap and rotor. But it still sputters in low rpm. Its sputters when you start out in any gear also. The sputter in the low rpm is really jerky also. I have also had the fuel pump amd filter changed also. All my vaccum lines seem to be in good shape. But still sputtering.... help me please
arthurromero is offline
post #2 of 2 Old 03-10-2012, 06:04 AM
Que89YJ
Check for fault codes and report back what you find:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
2.5 liter , 4 cyl , help needed , jerking , sputtering
sputtering zullo YJ Wrangler Technical Forum 3 05-17-2011 08:35 AM
yj sputtering stcarter44 YJ Wrangler Technical Forum 6 04-28-2011 09:08 PM
sputtering at take off BennyV TJ Wrangler Technical Forum 19 02-10-2010 11:05 PM
Sputtering doubleup TJ Wrangler Technical Forum 18 11-28-2007 11:51 AM
sputtering AGAIN StuckInMud94 YJ Wrangler Technical Forum 31 10-05-2005 10:21 PM
