Sputtering/loss of power in 1st-3rd gear - JeepForum.com
post #1 of 18 Old 10-13-2013, 02:59 PM Thread Starter
Bighaydn
I've got 1994 wrangler with the 4.0 HO. It's lifted And has big tires. Anyways if I'm at low rpms and just cruising through town in a low gear it kinda sputters and makes the whole jeep shake. I just bought it and it's alway done this. I did a full tube up and it helped but it still sputters. It's got gears and a locker too. Anything helps thank you
Bighaydn is offline
post #2 of 18 Old 10-15-2013, 09:09 AM
Que89YJ
The gearing has no direct electrical connection so I am wondering if you are dealing with a rpm issue or loading issue. Does it do it all the way through the gear range in 1/3? Start by checking your fault codes and post back what you get.
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #3 of 18 Old 10-15-2013, 09:39 AM Thread Starter
Bighaydn
No it's just when I'm starting I think it's just my locker engaging
Bighaydn is offline
post #4 of 18 Old 10-15-2013, 09:50 AM
Que89YJ
Only in 1/3? Any fault codes?
Que89YJ is offline
post #5 of 18 Old 10-15-2013, 10:03 AM Thread Starter
Bighaydn
It's 1st gear and sometimes 2nd and sometimes even 3rd. To be honest I think it's just my inexperience of driving it I mean I just bought it. And I'm at work so I can't check the codes yet. But It might be just be not giving it enough gas but I'm not very experienced with jeeps it's my First one
Bighaydn is offline
post #6 of 18 Old 10-15-2013, 10:59 AM
Que89YJ
The link in my post tells you how to check codes. You will get use to the jeep!
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 18 Old 10-15-2013, 11:12 AM Thread Starter
Bighaydn
Yeah I checked it out. That's awesome that I don't need a computer! Haha thanks for that. I'll do it right when I get off. Also though I should start a new thread but do you know much about leef springs?
Bighaydn is offline
post #8 of 18 Old 10-15-2013, 11:15 AM
Que89YJ
I am a electrical kind of person. There are many many many people here that know the suspensions better then I do. Post it up to a new thread. The Thread title will get you headed in the right direction by getting the peoples attention that do.
Que89YJ is offline
post #9 of 18 Old 10-15-2013, 11:20 AM Thread Starter
Bighaydn
Alright thanks. I'll get back once I check the fault codes
Bighaydn is offline
post #10 of 18 Old 10-15-2013, 07:01 PM Thread Starter
Bighaydn
Which makes sense since 24 is the throttle sensor
Bighaydn is offline
post #11 of 18 Old 10-15-2013, 07:02 PM Thread Starter
Bighaydn
The codes it gave me were 12 24 and 55
Bighaydn is offline
post #12 of 18 Old 10-16-2013, 09:37 AM
Que89YJ
I think your 24 is a 33. You should always see 12, 33, and 55. It sounds ok.
Que89YJ is offline
post #13 of 18 Old 10-16-2013, 11:53 AM Thread Starter
Bighaydn
No haha it's it was most certainly a 24 which is the tps censor
Bighaydn is offline
post #14 of 18 Old 10-16-2013, 12:29 PM
Que89YJ
Are you seeing a 33? You always, and I do mean always get a 33. Maybe video it to youtube and post a link so I can see the flashes.
Que89YJ is offline
post #15 of 18 Old 10-16-2013, 02:54 PM Thread Starter
Bighaydn
It gives a 12 24 and a 55 to end. It flashes twice fast then a break then 4 quick flashes. I read online that 24 means the tps sensor. I then googled and found a forum with guys having the same problem as me and it was there tps sensor
Bighaydn is offline
