Sputter, gas smell and limited speed - Page 4 - JeepForum.com
post #46 of 55 Old 06-21-2011, 01:21 PM Thread Starter
mgkbull
1987 YJ Wrangler
Bump
Here in New Mexico, we don't go mudding, we go dusting!
mgkbull is offline
post #47 of 55 Old 06-21-2011, 01:39 PM
dancytron
Did you try the knock sensor yet?
When my van's knock sensor went crazy, that's kind of what it did. The knock sensor listens for knock and retards the timing to keep you from hurting the engine. When it gives a false positive, it retards the timing which causes the vehicle to run bad on acceleration.
Other than that, you need to systematically go through the sensors to make sure they all work properly.
dancytron is offline
post #48 of 55 Old 06-21-2011, 01:58 PM Thread Starter
mgkbull
1987 YJ Wrangler
Oooh, I have not tried that... Gonna google how to test the knock sensor now.
mgkbull is offline
post #49 of 55 Old 06-21-2011, 03:30 PM Thread Starter
mgkbull
1987 YJ Wrangler
OK, where is this knock sensor located? manual says on the intake manifold in front of carburetor. Not seeing it.
mgkbull is offline
post #50 of 55 Old 06-26-2011, 01:09 PM Thread Starter
mgkbull
1987 YJ Wrangler
OK. All problems have been fixed. It wasn't the knock sensor, fuel filter or anything like that. It was the float level. It was set too low and hence wasn't getting enough gas. 25 minutes later I had it adjusted properly and bam, no more problems. She's running like a champ now.
Thanks to everyone for your help!
mgkbull is offline
post #51 of 55 Old 06-26-2011, 10:21 PM
monkeyhouse
awesome! Glad to hear it's all good and no knock sensor issue!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #52 of 55 Old 06-27-2011, 03:42 PM Thread Starter
mgkbull
1987 YJ Wrangler
Well, I spoke too soon. I can still smell gas, and I'm realizing that it had nothing to do with the prior issues with the carb. Doing a search throughout the forum however, looks like it might be a corroded rollover seal or that line canister line that goes up into the rear fender, above the exhaust pipe.
I'll look behind the brake light tomorrow and see if I can reach it. I hope it's as simple as replacing that!
mgkbull is offline
post #53 of 55 Old 07-30-2011, 09:43 PM
Missouribound
I recently replaced my BBd with a Weber...no gas smells anymore.
Missouribound is offline
post #54 of 55 Old 07-30-2011, 11:20 PM
monkeyhouse
which weber you runnin? your profile really isn't informative.
post #55 of 55 Old 07-31-2011, 07:46 AM
Missouribound
Sorry for the lack of detail. I purchased a kit "K551" from Carbs unlimited. It's a 32/36 Weber. I recommend the kit because it includes all linkage and very detailed instructions. You will lose the stock air cleaner though but the kit comes with an air filter assembly. Not a big job, but quite a bit of vacuum lines will disappear as you make the swap.
carburetor , carter carb , rebuild kit , sputtering
YJ Sputter fixnstuf3 YJ Wrangler Technical Forum 49 06-21-2011 07:42 AM
TJ, Surge/sputter @ highway speed ckcamer TJ Wrangler Technical Forum 13 06-13-2010 10:53 AM
Sputter (again)... VERY BAD! BChamberlin TJ Wrangler Technical Forum 7 10-23-2009 02:12 PM
rough idle and sputter at cruising speed CWD98TJ TJ Wrangler Technical Forum 8 09-01-2008 04:27 PM
Turn Key, Crank, Sputter, Sputter, Run.. JFiorentino TJ Wrangler Technical Forum 3 07-24-2004 10:34 AM
