Springs and shocks with ford 8.8 - JeepForum.com
post #1 of 19 Old 01-16-2014, 11:14 PM Thread Starter
tecksjeep
Hey guys, I'm upgrading my axles with a set I will pick up this weekend. I'm going 8.8 with 4.88 in the rear and a D30 with 4.88 and 1 ton steering in the front. I currently have an RC 4" lift and its crap. The shocks don't even allow for full flex. I want to get new springs and shocks, and I have 1.5" boomerang shackles. Zone leafs look okay and I heard they are sistered with BDS? And what size shock would go good? I don't have anything to help me measeure full flex. Suggestions please
tecksjeep is offline
post #2 of 19 Old 01-17-2014, 11:52 AM
StanF
If you are doing all this work with the axles and steering, have you considered going SOA at the same time? This would cause other issues that would need to be solved, but you might want to consider it.
Personally, I don't like 1.5" shackles - they are a bit long for my taste. I would remove them, and increase the spring lift (or go SOA), if you need the extra clearance.
Your local 4x4 shop should be able to help you do full flex - ramp or forklift.
StanF is offline
post #3 of 19 Old 01-17-2014, 02:44 PM
Randonexplosion
Randonexplosion's Avatar
If you absolutely don't have the means to articulate the suspension, and don't care if they are the perfect length, then just order some out of a catalog for your aprroximate lift size. http://www.quadratec.com/products/16070_204.htm
There has to be somewhere around that you can flex it out to measure.
Randonexplosion is offline
post #4 of 19 Old 01-17-2014, 03:30 PM
jokerchief462
Look up Kolak for a screen name ang get some Billstein 5100s for shocks. He can advise what shock length will fit your setup.
E mail kolak@aol.com
PM here on the site got mine for $271 to the door
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 19 Old 01-17-2014, 06:44 PM
Day215
I run zone 4" leafs and bezerk 3/8 booms, I'm extremely pleased with both.
Day215 is offline
post #6 of 19 Old 01-17-2014, 07:25 PM Thread Starter
tecksjeep
I've considered going SOA, I've got a drive shaft on order and have an SYE. Also the new axle i'm getting has a 1 ton steering setup on it already. I just really want to see what I can do SUA. I am also considering ditching those shackles and going with a 5" spring. I just dumped a lot of money into axles,drive shaft, and a few other things so 5" springs will have to wait. Is a high steering kit necessary for and SOA? I don't know a whole lot about that
post #7 of 19 Old 01-17-2014, 07:27 PM Thread Starter
tecksjeep
Are you using the shocks that came with the 4" zone lift?
post #8 of 19 Old 01-17-2014, 11:40 PM
Day215
I only purchased the spring packs, I reused he procomp shocks that were from my previous lift . I have heard really good stuff about bilstiens.
Day215 is offline
post #9 of 19 Old 01-18-2014, 01:04 AM Thread Starter
tecksjeep
Me too, just don't know what size to get. I am leaning towards the 'RE extreme 4" springs with listen shocks and a 1" day star BL. With some luck i should clear 35's
5.7 Vortec, D60 front w/ detroit,14 bolt rear w/spool. 16" FOA Coilovers in rear ORI struts in front, Barnes Enduro Joints, Daves custom boat sides/rear armor.
Check out my build here!
post #10 of 19 Old 01-19-2014, 01:48 AM
devoX13
Hope the axles work out great for you! I'd say measure for the shocks and get bilsteins. Seems to be thd popular opinion most times.
devoX13 is offline
post #11 of 19 Old 01-19-2014, 06:58 AM
bogleparsons
hope your drive shaft works out too, being that you are changing suspension and axle it would worry me not to measure it all at ride height before ordering.
(not that it can't be changed)
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #12 of 19 Old 01-19-2014, 07:07 AM
jsawduste
2006 YJ Wrangler
What does this mean ?
jsawduste is offline
post #13 of 19 Old 01-19-2014, 02:02 PM
Laid-Off
I am in the process of changing shock also, Here is what I came up with for my YJ (3.5" Black Diamond lift w/ 1.250" Booms, 35" MTR).
I have not bought the shocks yet, but my plans are for the Skyjacker M95.
I cross referenced the size shocks I have now (Skyjacker Hydros)
Hydros:_______________ M95:
Front 7059 ____________ Front M9561
Col. 16.56"____________ Col. 17.42"
Ext. 28.75" ____________ Ext. 30.46"
Rear 7088 _____________ Rear M9558
Col. 14.82" ____________ Col. 14.82"
Ext. 24.84" ____________ Ext. 24.84"
For their listing for 4" lift is the 7059/7088 and M9559/M9558
For their listing for 5-6" is the 7061/7088 and M9561/M9558
Laid-Off is offline
post #14 of 19 Old 01-19-2014, 02:46 PM
Day215
1.25" booms would be pretty long wouldn't they? I would say a 1" body lift with a smaller shackle would be preferred. I clear 35" MTR's with 4" leafs, 3/8" booms and some body trimming. It may not look like the biggest jeep on the planet, but the tires clear and it keeps it low.
Day215 is offline
post #15 of 19 Old 01-19-2014, 04:16 PM Thread Starter
tecksjeep
Thanks man! That's extremely helpful.
