#1 | |
springs, axles, and swapping?
Hey everybody, i have a yj and i see that people swap out xj leaf's onto their yj. i was wondering if thier a direct swap and what kinda lift do they give. also ive been looking around at axles, i want to do a 350 swap and run 37-40 tires, and i found rockwells for around 500 bucks per 2.5 ton axle. which brings me to my next question why dont you see any under jeeps? and finaly where would i find the 231c, i think it is, to bolt up to the chevy trans? thanks a lot guys
#2 |
xj leafs are a little longer than yj springs and give about 2" lift IIRC.
I believe the main downfall to rockwells are: pinion brakes 6.72 gears (no other choices that i know of) weight center section usually gets shaved different bolt pattern and probably a few other things to add. Not saying it's not a good choice just giving you possible reasons. Can't help you with the t-case sorry
1994 YJ 4.0L 5 spd. flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works http://i178.photobucket.com/albums/w257/mwchitty/Image075.jpg |
#3 |
you cant drive on the street with a pinion brake in most states. Unless you do the disc brake conversion on a Rockwell, (wich cost about $1500 per axle) you are pretty much making your Jeep a trail only rig.
#4 |
Quite a few jeep here in florida run them, but they are all mud only jeeps.
/l ,[____], War doesn't decide who's Right? Only who's Left!
l---L 0lllllll0- ()_) ()_)--o-)_) |
#5 | |
Rockwells are all over the place here, but they are trailer queen rock crawlers that ride on 44"+ tires and usualy have a healthy v8 and run a minimum of 4:1 geared D300's or Stak or Atlass Tcase or something of the like.. Also, most of the guys who wheel them, use 2 steering axles. ![]() |
#6 |
awsome guys. that helps a lot. no one has any reply on where to get the
231c for the 350 swap? and whats the difference betweet the two transfer cases |
#7 |
TH350 trans or Small Block Chevy 350 CID engine?
If you are looking for a TH350 trans to a NP231 adapter... check with Advanced adapters or Novac Conversion. |
#8 |
XJ on 37's
the 231 c came behind the 700r4's in s10 blazers and the like.
i dont think they came behind any other tranny (350,400 etc), so it would be counter productive to use in that case. different output shaft on the tranny i believe. get the t/case that came behind it, and then you could maybe run a passenger side drop front axle (dana 60), which are cheaper than a driver side drop due to everyone wanting them for the jeeps they own......like me! ![]() martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#9 |
I'm looking for the 231c as well, and according to everything I've read (which could be wrong, you never know) the right case to get is behind the auto v6 chevy s-10 4x4 from 88 - 92 (?). Snag the tranny too, its a 700r4. If I'm wrong, someone else can correct me.
1987 YJ 4.2l crappy BA 10/5 stock |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
