Spring & Shackle question - JeepForum.com
post #1 of 20 Old 12-05-2013, 09:01 AM Thread Starter
rollover755
Ok, I built some spring shackles from measurements from another set of shackles i had around here and now I'm ready to install and I have a gap from the bushing to the shackle(see pic below). Can I make a spacer or longer center sleeve? Does the bushing need to be touching the shackle ? I've heard I need to torque the bolt but with the center brace not sure torquing will matter... Any input would help a ton guys.... Thanks
rollover755 is offline
post #2 of 20 Old 12-05-2013, 09:12 AM
jbolty
jbolty's Avatar
get rid of the center brace. the side plates need to be torqued against the bolt sleeve, which needs to be exactly the right length to keep the shackles straight and move without binding.
jbolty is offline
post #3 of 20 Old 12-05-2013, 09:21 AM Thread Starter
rollover755
ok Thanks, I was always wondering if that center brace even helped or not !?!? I've been reading anywhere between 45lbs and 65lbs, is this correct ??
post #4 of 20 Old 12-05-2013, 09:46 AM
Chrisnvegas
Chrisnvegas's Avatar
95 and 105.
If you have to leave the shackles loose, you have the wrong metal sleeves in the bushings. Mine are torqued to 95 lb ft and 105 lb ft. It would ride no different if I left them loose.
My Jeep is NOT a Fiat!
Chrisnvegas is offline
post #5 of 20 Old 12-05-2013, 03:03 PM Thread Starter
rollover755
Is there a different torque for front(shackle) of spring or frame side? will this apply for rear springs too ??
post #6 of 20 Old 12-05-2013, 04:25 PM
Chrisnvegas
Frame 105 (100 will do) spring eye 95
Chrysler Jeep shop manual
post #7 of 20 Old 12-06-2013, 01:03 PM Thread Starter
rollover755
ok thanks... I am going to replace the frame bushings first tho... I can see the rubber is blown out past the sleeve and i think it will bind when I torque.... Whats the best or easiest way to replace these ???
post #8 of 20 Old 12-06-2013, 01:29 PM
bpounds
bpounds's Avatar
Not to contradict any of the others advice, but I do notice that you've got the bushings pushed together and you're assuming that means there is a problem with the width. Not so. The poly bushings don't necessarily need to be touching in the center of the spring eye. What matters is the length of the sleeve bushing on the bolt, which isn't shown in that pic.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #9 of 20 Old 12-06-2013, 02:38 PM Thread Starter
rollover755
good point.. i checked it in the spring too and it also had this gap.. I have made a new set of shackles so I can torque them properly. I'm heading to shop now to get this thing done !!!
post #10 of 20 Old 12-06-2013, 03:05 PM
baritone_mike
Warrior Products, which look a lot like your shackle, recommends 30lbs for both ends of the shackle.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #11 of 20 Old 12-06-2013, 03:24 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
if you are going to do 30lbs make sure you use nylon lock nuts
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #12 of 20 Old 12-06-2013, 03:37 PM
baritone_mike
6 of them are nylon (they came with the shackles) the other 2 are rust-tighted OEM.
post #13 of 20 Old 12-06-2013, 03:40 PM
Chrisnvegas
The bolts WILL wear out and eventually fail. Hopefully this will not occur on the highway.
post #14 of 20 Old 12-07-2013, 12:58 AM
baritone_mike
What is the reasoning behind this, they are torqued to manufacturer spec, My Jeep rids so much better now than it did before loosing up the shackles (I had to use a breaker bar to get the bolts loose)
post #15 of 20 Old 12-07-2013, 06:20 AM
fishadventure
the nuts should be torqued to the center spacer sleeve- they shouldn't be clamping down on the bushings beyond the manufacturer's intended design. That is the only way you will be binding.
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
