Spring rate for RE 4.5 XD - JeepForum.com
post #1 of 5 Old 04-11-2005, 01:34 PM Thread Starter
4bangerYJ
If you are running the RE 4.5 XD springs can you tell me what the spring rates are front and rear. If you don't know use the following link.
http://www.therangerstation.com/tech...springrate.htm
With a few measurments it takes just a couple of minutes. Measure at ride height.
Thanks!
4bangerYJ is offline
post #2 of 5 Old 04-11-2005, 08:04 PM
PhilipJ
PhilipJ's Avatar
This is what I got:
Front: 147.17 lbs-in (.25"H x 2.5"W x 48"L x 5 leaf)
Rear: 176.61 lbs-in (.25"H x 2.5"W x 48"L x 6 leaf)
Keep in mind these leaves have military wraps, bolted spring clamps and teflon pads which probably aren't factored into the calculator.
PhilipJ is offline
post #3 of 5 Old 04-12-2005, 12:05 PM Thread Starter
4bangerYJ
Thanks! Is that 48 inch measured from the center of the hole on each end of the spring? Like where the bolt goes thru to hold it to the shackle and the spring mount on the rear of the spring.
I am just gathering info, Thanks!
post #4 of 5 Old 04-12-2005, 06:19 PM
PhilipJ
PhilipJ's Avatar
48" was the best guesstimate I could make using a metal tape under the vehicle while trying to hold it and keep it from bending. Kinda hard to measure those things when they're already installed. I measured from end to end, so eye to eye would actually be a little less.
PhilipJ is offline
post #5 of 5 Old 04-12-2005, 07:46 PM Thread Starter
4bangerYJ
Cool thanks. I thought 48 was a bit long.
Spring Rate Spring Info Thread mississippi_xj YJ Wrangler Technical Forum 32 07-11-2013 03:37 AM
RE Spring Rate BYuen TJ Wrangler Technical Forum 1 01-20-2008 11:36 AM
RE Spring rate? chefdab TJ Wrangler Technical Forum 4 01-03-2008 12:01 PM
what OME spring rate should i get? paroxysym TJ Wrangler Technical Forum 2 04-26-2005 11:20 AM
Spring Rate Rufies97XJ TJ Wrangler Technical Forum 0 01-20-2004 11:55 AM
