Spring over without axle wrap (traction) bar, who's done it?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Spring over without axle wrap (traction) bar, who's done it??
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-11-2013, 07:16 AM   #1
redmanwalking
I have most of the parts together to do a spring over conversion on my YJ. I'm currently running a Rough Country 4" lift and I'm looking for more "compliance" out of my Jeep.
I am using stock YJ springs, an 8.8 with 4.10's and limited slip. I have a SYE and a CV driveshaft. I'm going to run my 33's for now.
I am getting very mixed reviews on running or not running an axle wrap (traction) bar. I've seen the kits out there but don't know if its worth spending the money. I've been told with the spring over perches and my tire size, it won't be a problem. I've been told that with stock springs and no bar, it will wrap immediately. So...
Who out there in spring over land is not using a wrap bar with stock springs?
Who ran without one and ended up having to add one? Did it compromise the spring once it wrapped?
The quicker I get this figured out the quicker I can stop going to my chiropractor after a wheeling trip and discover this strange thing called "flex".
redmanwalking is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 07:49 AM   #2
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
I run one. Don't see any reason not to. Would you rather save the money now, then have to replace rear springs and DS ujoints later down the rd? If you don't want to spend the money to buy a prefabbed one just make it yourself. I've made a couple and they're stupid simple
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 09:11 AM   #3
bmgadg
I built mine. It was a necessity for my rig. I was getting major axle wrap that was snapping yokes.
My v8 YJ Build Thread
bmgadg is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 09:16 AM   #4
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Either put one in at day one, or break shtako for as long as your wallet and pain level last, then put one in.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 12:44 PM   #5
Helldorado Customs
Addicted...
Helldorado Customs's Avatar
You note that everyone above this post has mentioned getting one. I'll be no different.
I will first clarify tire size as a component of axle wrap. It's not. As long as the tire can gain traction...you will encounter axle wrap, however minimal or extensive it is. A 33" tire can gain 100% traction the same as a 35" tire....therefor, axle wrap is inevitable. Traction + torque = axle wrap. You can minimize it with military wrap springs and extra leafs clamped in there...but then your taking away from the reason you want SOA....flex. As mentioned above, put it on now and save yourself headache later. To answer your other question, yes...it will damage the spring if you "go to far".
Note the next picture, the guys to the left have the "startled" look about them. They had just heard my axle wrap to the point of shearing off my anti-wrap bar from the axle tube, causing the chain reaction of the driveshaft snapping in two and coming up through the floorboard...ironically, the "obstacle" was called Double whammy.
I like to build stuff. Want to know what I build, you can google it HERE
Helldorado Customs is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 01:42 PM   #6
kloppk
I'll join the chorus of been there, tried that.
I started out with an 8.8 & SOA with 33" tires with no anti-wrap bar. Mistake....
Like most others I quickly learned the need for the anti-wrap bar as I was bending the crap out of springs, blew a rear driveshaft, etc.
I fab'd up an anti-wrap bar based the DIY version on Pirate. Problem solved. Spring lasted much longer and no more axle wrap.
Moved up to 35's and it still worked great.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 03:10 PM   #7
redmanwalking
I appreciate the input fellas. Consider it done.
Unread 07-11-2013, 03:45 PM   #8
remmons
remmons's Avatar
2015 KL Cherokee
I am currently filling my bucket-list of parts for a SOA, and one of the parts that I am going to get is the traction bar. Sure, I have read and heard on several sources that axle-wrap can be reduced or eliminated by installing an add-a-leaf to your spring pack. But, as Helldorado Customs has stated, you will be taking away from the flex that you are looking for.
Just remember, it is always better to do it right the first time.
A thought to ponder on. Some people can't afford to do it right the first time, but end up doing it for the second time.
Robert.
2015 Cherokee Trailhawk V6.
remmons is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 08:24 PM   #9
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Scott? It sure looks like your YJ ahead and mine from the passenger door area taking the pic.
BOT: I know you already mentioned it - but this is for the folks who'll be reading/searching this forum.....Yea, get a traction bar, you'll thank yourself.
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 08:31 PM   #10
TSEJEEPERS
TSEJEEPERS's Avatar
I am one of the ones that ran without it.
At the time I did my first SOA I really did not know about axle wrap.
I was blowing out rear driveshafts left and right.
It got exspensive real quick. I even got to the point that I carried a spare driveshaft. I could change it out on the trail in 5 min. or less.
CV driveshafts are exspensive.
I was running RE SOA springs with stockish spring perches.
Now with that said I do have freinds that run SOA with out a anti wrap bar.
Most also run V 8s and do not have a problem.
I am really not sure why.
Longer spring perches with heavier springs maybe?
They all seem to flex well.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 08:37 PM   #11
Helldorado Customs
Addicted...
Cheers Joe ! Hows life in cali treatin ya ??
Unread 09-06-2013, 10:58 PM   #12
wickedoffroad
1987 YJ Wrangler
As stated above, get it on early. I went with a rancho 4.5 inch springs and SOA. Always had a thunk or clack when starting out or letting the clutch out when shifting. I would climb out and loook everything over, shaking this, pulling that and everything was tight. The other day the jeep was acting funny. Felt like the rear was hopping. Made it the 30 miles to home on the freeway (60+ mph) Pulled into the alley about 200 yards from home, SNAP. Jeep locked up. The CV joint was sheered in two and the driveline was firmly crammed up into my exhaust. I was extremely lucky that it didnt go out on the freeway at top speed. Save yourself the expense, work and possible danger and do it with the SOA.
wickedoffroad is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 11:16 PM   #13
Burlbook48
Trial By Trail
Burlbook48's Avatar
Well? Did you Install an anti-wrap bar?
BTDT ...Got a broken axle flange to prove it. SOA= Anti-wrap bar.
Happier now. Nuthin' broke to prove it.
You have to start somewhere to get to the middle of nowhere.
Burlbook48 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2013, 12:02 PM   #14
Ripper3494
i did the second one and regret it haha
build thread:
[url]http://www.jeepforum.com/forum/f22/94-yj-6-0-build-spud-1218315/[/url]
1997 ZJ limited - BONE stock
[url]http://www.jeepforum.com/forum/f12/alternator-welder-write-up-1301614/[/url]
[url]http://www.jeepforum.com/forum/f12/tj-uppers-yj-half-doors-hard-top-installation-1417686/[/url]
RC vs BDS
[url]http://www.jeepforum.com/forum/f12/rough-country-vs-bds-1461555/[/url]
Ripper3494 is offline   Reply With Quote Quick reply to this message
Unread 09-07-2013, 12:54 PM   #15
rshbutch
Spring over,no traction bar. Been running ducy-ershim trail for years. Axle wrap has never been an issue. Auto vs stick, stick will need the bar,auto is kinder to the drive line
rshbutch is offline   Reply With Quote Quick reply to this message
axle wrap , soa , spring over , trac bar
