Spring Over vs. Spring Under - JeepForum.com
post #1 of 9 Old 04-06-2011, 02:14 PM Thread Starter
gnisty
1987 YJ Wrangler
I am interested in putting a very small lift on my '87 YJ. I don't want more than about 2.5". Even 1.5" would be ok.
Can anyone offer me opinions or stories that are good, bad or indifferent for a spring over conversion?
gnisty is offline
post #2 of 9 Old 04-06-2011, 02:17 PM
YJteen
It isn't as cheap as you would think and its more like a 5 inch lift. You really should have some type of high steer setup which can get more expensive than a small lift kit.
My vote is OME 2.5 inch lift. If you wanted like 1.5 inches just get their light duty and it should be close to 2 after it's broken in.
95 Rio Grande YJ. Power generously provided by 4 angry squirrels and a 20 gallon squirrel feeder. Sitting on 31x10.5 ATs with AR wheels
Yes I'm 20, Yes I like Jeeps, Yes I do not know everything
Originally Posted by GrandLaredoWJ
You should be fine with the axle setup, just as long as you don't beat on it as hard as you would looking at a Playboy magazine, the d30 and d35 should hold up.
YJteen is offline
post #3 of 9 Old 04-06-2011, 02:21 PM
dimatrod
SOA will give you a ~4" lift, and you'll have to invest in other things, including a SYE kit or transfer case drop.
You can easily manage a 2" lift by adding an extra leaf, be it custom made or from a chevy S10. You'll have a slightly stiffer ride, but the extra clearance is great. Later on you might think about a tummy tuck, which will grant you higher clerance and will include a body lift, also giving you space for bigger tires (even higher clearance).
dimatrod is offline
post #4 of 9 Old 04-06-2011, 02:25 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
look at 2" lift springs for spring under
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #5 of 9 Old 04-06-2011, 02:41 PM
TheNewbie
Then forget about a spring over.
If you want something in the 2.5" range then get a 2.5" lift spring kit.
If you want less you can go up at an inch with a shackle lift and another inch on body lift and keep your stock springs.
What size tires are you trying to run? Will you be doing much off roading?
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #6 of 9 Old 04-06-2011, 02:59 PM Thread Starter
gnisty
1987 YJ Wrangler
Currently, this Jeep is my daily driver. I spend my weekends at the river, running ATV trails, racing my buddy in the sand, and low water crossing for island hopping. We probably burn a tank or two on a good weekend at the river.
For this Jeep, I am just wanting a little more clearance for some of the minor obstacles that we encounter. Its a YJ, so I won't be doing any heavy wheeling in it until I can change out the entire drive train.
The biggest tires I'll run, with this drive train, are 31". Currently, I have 235/75R15's. With a tape measure, they measure just over 27.5". I will most likely leave them installed untill the tires actually need replaced.
gnisty is offline
post #7 of 9 Old 04-06-2011, 03:39 PM
MudWrangler
I have SOA lift and trust me for the wheeling you are planning to do you do not want the hassle or the spending of $$$$$$ involved in a SOA
Bry
MudWrangler is offline
post #8 of 9 Old 04-06-2011, 04:01 PM
TheNewbie
If you only plan on going up to 31's at the most don't even consider SOA. Those tires would be waaaay too small in my opinion. A spring over will net you at least 5.5" of lift. And it would be much more expensive than a small or medium suspension lift if done right.
Most guys running a spring over are on at least 35's.
For 31's you could just swap in a 1" body lift and some small lift shackles and call it good. You don't even need lift springs to get 31's under the YJ.
post #9 of 9 Old 04-06-2011, 04:53 PM
RUBICON_TERRY
I agree with THENEWBIE he hit the nail on the head for what you do a one inch body lift and a small shackle increase will work perfect for you and will not break the bank
RUBICON_TERRY is offline
Spring Rate Spring Info Thread mississippi_xj YJ Wrangler Technical Forum 32 07-11-2013 03:37 AM
Any ways to compress a spring other than spring compressors? wmeyer116 TJ Wrangler Technical Forum 7 09-02-2009 07:36 PM
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 08:32 PM
why is my front right spring rubbing the spring perch? ClemsonJeepGC TJ Wrangler Technical Forum 12 06-07-2006 08:44 PM
What spring company has super soft spring rates for articulation prposes? jeepcj7 YJ Wrangler Technical Forum 3 04-19-2004 09:14 PM
