spring over with chry 8.25 - JeepForum.com
post #1 of 3 Old 05-04-2007, 08:54 AM Thread Starter
iwishihad1
hey everybody
im an Xj guy but ive got an 8.8, and am getting rid of my rear chry 8.25. i have a friend who is thinking about using it for when he goes SOA. are the perches the same width for both jeeps, or would we have to cut the old spring mounts off and weld new ones on. hes got 1.5 inch springs, so with SOA would he have to re-do his steering, or would a pitman arm, and tracbar drop do the job
and he knows he has to do SYE/cv shaft also
iwishihad1 is offline
post #2 of 3 Old 05-04-2007, 09:56 AM
Tulsachokehold
SOA = some form of high steer set up for it to work correctly.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline
post #3 of 3 Old 05-04-2007, 11:16 AM
Ares
Ares's Avatar
You would need the high steer to set it up correctly, since he will be running what....6" of suspension lift at least. And The perches will have to be cut and re-welded. I believe the cherokee perches are narrower then the YJs
- Cameron
Ares is offline
Spring Rate Spring Info Thread mississippi_xj YJ Wrangler Technical Forum 32 07-11-2013 03:37 AM
Any ways to compress a spring other than spring compressors? wmeyer116 TJ Wrangler Technical Forum 7 09-02-2009 07:36 PM
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 08:32 PM
why is my front right spring rubbing the spring perch? ClemsonJeepGC TJ Wrangler Technical Forum 12 06-07-2006 08:44 PM
What spring company has super soft spring rates for articulation prposes? jeepcj7 YJ Wrangler Technical Forum 3 04-19-2004 09:14 PM
