spring over brake line question - JeepForum.com
post #1 of 10 Old 02-24-2002, 11:44 PM Thread Starter
JYRUS
with the RE springover kit do you relocate the brake lines or just tie them in the factory spot that sits atop the frame?
JYRUS is offline
post #2 of 10 Old 02-25-2002, 09:18 AM Thread Starter
JYRUS
JYRUS is offline
post #3 of 10 Old 02-25-2002, 11:29 AM
SethNCSU
I'm not sure what you are talking about, but the kit comes with longer brake lines that you mount in the same position as stock. I had to zip tie mine to the shock though because it was rubbing the tire. Hope that helps you.
SethNCSU is offline
post #4 of 10 Old 02-25-2002, 10:27 PM Thread Starter
JYRUS
i called RE today and the said to redrill new holes on the side of the frame and relocate them to allow them to be longer.
JYRUS is offline
post #5 of 10 Old 02-25-2002, 11:16 PM
osburn
osburn's Avatar
If you're talking about relocating the hard line, I ran mine below the frame. Just carefully bend it downward and don't kink the line. I didn't have to drill any holes. I just used the rear bolt on the bumpstop to fasten the bracket to the frame.
Matt Osburn
Score 1032
osburn is offline
post #6 of 10 Old 02-26-2002, 02:39 AM Thread Starter
JYRUS
i am talking about in the front?
JYRUS is offline
post #7 of 10 Old 02-26-2002, 09:29 PM
osburn
osburn's Avatar
So am I!
Matt Osburn
Score 1032
osburn is offline
post #8 of 10 Old 02-27-2002, 08:17 AM Thread Starter
JYRUS
gotcha, would it be easier to run it down the front of the frame.
JYRUS is offline
post #9 of 10 Old 02-27-2002, 09:00 PM
yj1988
I ended up with a different method after getting tired of my brake lines either being streched too much or rubbing, even after making them longer. I ran braided line to a T mounted on the diff case and down each tube to the brake calipers. This way I have plenty of flex going to the center of the diff and I can drop a tire or stuff it as high as I want with no problems. Do it once and do it right, it will never come back to haunt you.
Lockers, Rockers and a 22,000rpm Margarita Blender
yj1988 is offline
post #10 of 10 Old 02-27-2002, 10:45 PM
osburn
osburn's Avatar
I'll agree that is a trick way to do the brake lines. And very effective for off road use. But, those lines are seperated for a reason. Safety. You won't lose both front brakes on a single line failure. Can't say I'd ever recommend this sort of thing on a Jeep that sees highway duty.
I simply bent my hardline and ran it down the inside of the frame. The bracket winds up near the rear of the front bumpstops. I just pulled the rear bolt of the bumpstop and ran it thru both the bracket and the bumpstop.
Matt Osburn
Score 1032
osburn is offline
brake line question jwrangler91 YJ Wrangler Technical Forum 0 05-04-2009 10:36 AM
Brake Line question. denwagh YJ Wrangler Technical Forum 2 04-30-2007 05:29 PM
brake line question scrnnmssuck TJ Wrangler Technical Forum 4 12-10-2006 11:47 AM
Brake line and E-brake Question vdubstreets YJ Wrangler Technical Forum 43 12-28-2005 08:02 AM
8.8 Brake question - connecting to the exisiting hard brake line? BNovak TJ Wrangler Technical Forum 2 06-10-2005 03:25 PM
