Spring Over Axle - JeepForum.com
post #1 of 4 Old 02-14-2002, 08:51 AM Thread Starter
Scratch
Spring Over Axle
How much will this lift my yj? When I do this, Will I have to change out my driveshaft and get a longer one to accomodate for the lift? Do I need to use perches on my axles for the springs to sit?
90YJ Hrd Top "Made from "Scratch"
Rblt 2.5 .60ovr
Reblt ax-5 tran
31x10.50 BFG AT
Scratch is offline
post #2 of 4 Old 02-14-2002, 09:43 AM
RodeoRob
RodeoRob's Avatar
It should net you somewhere around 5" of lift, but it will vary. you will need new spring perches welded on top of the axle for the springs to sit on. You can buy generic weld-on perches for around $10-15 a piece. You will most definitely need to change your driveshaft, get it lengthened at the vary least. But more realistically, you'll probably been a slip yoke eliminator (SYE) with a CV driveshaft to accomodiate the new steep angles.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 4 Old 02-14-2002, 10:30 PM
YJ boy
Rob is right it will give you about 4.5 to 5.5 lift. I did mine and it was 5" you will need drop pitman arm, longer driveshaft, perches,longer brakelines, longer shockes, and a good welder. you can get a good write up on soa if you go to this location
www.jeeptech.com/convaxle/fordeb/soa.html
you can also get there from the jeep project section in www.jeepyj.net
Good luck if you want a pic. of the finished product just e-mail me mine is a 90yj
YJ boy is offline
post #4 of 4 Old 02-17-2002, 08:57 PM
batman
I recently got my new Quadratec magazine which had a set of soa paerches that bolt on to the axles. Seems like easy way to do an soa for a novice jeeper. It says that it is 4.5" lift. It doesn't include anything else like shocks or drop pitman arm. This is the first time i've seen anything like this. I'm curious to see if it works well. The down side is it costs about $400.
94 YJ 2.5L, 4" superlift, 33" Radial MT, wet okole seat covers, Sunrider soft top, front and rear light guards, billet grill, clarion cd player, 2-10" RF subs, soundbar, tb spacer. Thats all I can afford with school.
batman is offline
Spring over axle kit available? oilburnnjeep YJ Wrangler Technical Forum 8 04-15-2009 08:06 PM
Spring over axle pcr451 YJ Wrangler Technical Forum 2 06-20-2005 02:23 PM
Spring Over Axle ScratchingWezel YJ Wrangler Technical Forum 24 05-08-2003 09:52 PM
spring over axle kit butters YJ Wrangler Technical Forum 0 02-27-2002 03:34 PM
Spring Over Axle? Trucidus Sum YJ Wrangler Technical Forum 14 01-04-2002 09:47 PM
