Is the spring over axel (SOA) street legal??? - JeepForum.com
post #1 of 6 Old 03-07-2002, 12:16 PM Thread Starter
92Wrangler15
I was wondering if you put the springs on top of the axels if it is steet legal or not. I hear good things about this conversion, and was also wondering if I would need an additional lift if I wanted to put 32 inch tires on??
THx
1992 YJ, 4 cylinder STOCK (trying to get the 6 cylinder in)
92Wrangler15 is offline
post #2 of 6 Old 03-07-2002, 12:40 PM
dennisuello
dennisuello's Avatar
SOA is legal, look under a lot of trucks and even Cherokee, they are SOA stock. SOA gives you about 5" of lift and you can fit 33s comfortably. If you go that route I'd suggest replacing stock springs with some heavy-duty ones.
SOA requires other modifications if you were to do it right. You'll need SYE, steering correction. You'll need to regear to push those bigger tires, too.
THx
dennisuello is offline
post #3 of 6 Old 03-07-2002, 04:18 PM
ebhub
SOA may be legal but if you drive the jeep on the street you might want to check local lift laws.I know here in Mass they can be real pains about your heigth.If you go too high(if there is such a thing)you might be asking for trouble when you drive it.
ebhub is offline
post #4 of 6 Old 03-07-2002, 07:22 PM
osburn
osburn's Avatar
I'm damn near positive there's a few states where the SOA conversion is not legal. It is legal in California. That's the only one I'm sure of. Oh, and Arizona I would imagine. Anything is legal there. The rest you'll have to check for yourself.
Matt Osburn
Score 1032
osburn is offline
post #5 of 6 Old 03-07-2002, 07:35 PM
evilpsych
evilpsych's Avatar
hey os.. how'd you manage to squeeze that NV4500 in yoru rig with only a 1" body lift? just lookin at your site there..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #6 of 6 Old 03-07-2002, 07:37 PM
osburn
osburn's Avatar
By "massaging" the tranny tunnel.
Matt Osburn
Score 1032
osburn is offline
5.7L HEMI in JK, street legal? JeepMan1975 JK Wrangler Technical Forum 37 07-16-2010 04:03 PM
Building the PERFECT street legal TJ. AlexGeorgakis TJ Wrangler Technical Forum 54 10-22-2009 09:43 AM
Big Street Legal Jeeps? Briznett YJ Wrangler Technical Forum 33 07-25-2007 12:05 AM
Need ANYBODYS Help- Is My Jeep Street Legal? Fix-N-2 YJ Wrangler Technical Forum 15 05-29-2007 05:51 PM
Which street legal fog lamps are best? bheiser TJ Wrangler Technical Forum 11 11-16-2006 09:21 PM
