spring over - JeepForum.com
post #1 of 11 Old 05-16-2012, 12:43 PM Thread Starter
jeep16
spring over
im considering going spring over on my jeep. im in the process of planning out the cost so i was wondering what parts i will need. so far what i have come up with,,,
-slip yoke elim.
-spring over kit
If i do a t-case drop do i need the SYE?
what do i do for steering setup?
thanks. Joe.
jeep16 is offline
post #2 of 11 Old 05-16-2012, 01:56 PM
YJ_Squared
Before anyone else chimes in, I am going to recommend you read about soa until your eyes bleed. I am planning on going that way this winter and I have already exhausted every piece of information I can find.
1995 YJ, just getting started.
2012 F150 FX4 Tow Rig
2003 Kawasaki KFX 400
YJ_Squared is offline
post #3 of 11 Old 05-16-2012, 02:52 PM
buckedgabers1
sye
perches
brake lines
might as well do axles while its all apart
springs cuz old ones are ganna sag
drive lines
new shock mounts and shocks
high steer or jb4x4 knuckle
alot gos into it its not cheap or quick great ride if done right cheaper and easyer to buy a sua kit
My junk is bigger than your junk
buckedgabers1 is offline
post #4 of 11 Old 05-16-2012, 02:57 PM
scubamc
Start reading.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #5 of 11 Old 05-16-2012, 03:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Continued reading...
Remember. Until your eyes bleed.
Luck Favours The Prepared
Anticanman is offline
post #6 of 11 Old 05-16-2012, 03:59 PM
giggityjeeper
-slip yoke elim.
-spring over kit
If i do a t-case drop do i need the SYE? REALLY???????? why do it all....... do it or dont do it.
thanks. Joe.
SOA kits are uselesss......... so far you hav ethe SYE part right.....
READ READ READ..... then come back and ask questions of all the SOA I know of only 1 person used that kit.... and of all the **** they send you only need the perchs.... you dont reuse trac kbars etc...
anyhow Im not getting into it.... just read lots... first thread in my sig is mine, or most of it.... high steer and some other stuf was added after it was completed, but I think its in there to....
I used rocky road highsteer
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #7 of 11 Old 05-16-2012, 08:15 PM
Nickabis
Alright, I hate to hijack but I have a few questions as well. I have read and read and so on. My original plan was to stay sua and cut, trim, raise and anything else I could do to get 35's but I was talked into a soa so build plans changed.
I've been collecting parts (stock springs, sye, 8.8 already installed, tires and wheels), I need to get or build some things (anti-wrap bar, spring perches, shock mounts, u-bolts and plates) and some things I'm going to get during the swap (driveline, shocks, brake lines, sway bar disconnects). I'm probably missing things in my lists but it's a general list. Feel free to add something if I forgot.
My biggest concern is my steering. I wanted to keep my budget low-er (highly unlikely) so a full high steer kit is in my budget. I saw JB4X4 has there raised steering bracket for a crossover steering, more in my budget but was curious about the crossover. I've also been reading on the WJ knuckle swap but I have warn's dana 30 manual hub conversion and I wasn't sure if it would work with the WJ knuckles and rotors. I've been searching these questions but coming up with conflicting answers so I thought I'd ask.
Thanks!
Nickabis is offline
post #8 of 11 Old 05-16-2012, 08:22 PM
idskot
Originally Posted by buckedgabers1 View Post
sye
perches
brake lines
drive lines
Not to mention Anti-Wrap, that's a good $250 right there.
idskot is offline
post #9 of 11 Old 05-17-2012, 07:01 AM Thread Starter
jeep16
im probably doing an anti rap regardless so thats not a big deal. as far as axles i already have an 8.8 and geared.
jeep16 is offline
post #10 of 11 Old 05-17-2012, 07:06 AM
Siva283
I would say let your eyes heal once they bleed and then read till they bleed some more. I want to do this as well I have been researching here and there for a year and probably have atleast another year before I will even be close to ready to do it. I will be doing research on it until I have nightmares about it.
Ask me how I know...
Siva283 is offline
post #11 of 11 Old 05-17-2012, 07:09 AM
giggityjeeper
an your already talking about skimping... the comment on teh tcase drop....
said itbefore and I will say it again, skimp or cut corners on a SOA and you end up with a POS jeep that you dont want to drive....
your on the right track mostly, just keep going down the right track...
if your gonna do it ....do it... if your thinking already of saving money and cutting corners STOP now.... stay SUA....
@NICK....
your steering is the ONE place you dont skimp out or cut corners... I went rocky road highster kit... yep its pricey most are, cost of going SOA....
and even with all the reading, once you get it apart you will run into issues that are just cause........ I bet you I spent another $500 bucks opn **** like new ubolts, couple body mount bushing were gone, new brake lines as a couple beokre... etc.... it adds upi fast, the main stuff is the easy stuff usually.... its the other **** you run into
I didnt see anyone post you need a new rear driveshaft to.....
Spring Rate Spring Info Thread mississippi_xj YJ Wrangler Technical Forum 32 07-11-2013 03:37 AM
Any ways to compress a spring other than spring compressors? wmeyer116 TJ Wrangler Technical Forum 7 09-02-2009 07:36 PM
Door paddle spring broke. Buy just the spring? ritjobbie YJ Wrangler Technical Forum 10 01-23-2009 09:56 AM
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 08:32 PM
What spring company has super soft spring rates for articulation prposes? jeepcj7 YJ Wrangler Technical Forum 3 04-19-2004 09:14 PM
