Spring Bushings....? - JeepForum.com
post #1 of 4 Old 08-05-2009, 11:06 AM Thread Starter
fishmanwill
1987 YJ Wrangler
I am getting ready to replace the front shackle hangers and I was wondering what else I should replace. I figure I should replace the bushings on the springs. I am also going to install new shackles. The shackle hanger kit from ruffstuff came with the bushings for the shackle hanger. What other bushings do I need and how many( 2 per spring??)? Are the front and rear spring bushings the same? Any advice from people that have done this would be appreciated thank you.
Will
1987 Wrangler
4.0L swap, AX-15 swap, and NP231
fishmanwill is offline
post #2 of 4 Old 08-05-2009, 12:34 PM
gunnorthered
If your only replacing the shackle hangars then you only need the shackle bushings. Most new shackles come with shackle to hanger and shackle to spring bushings. As far as the main eye bushings go, stock ones I believe are 1-1/4" while most after market are 1-1/2". Unless you have stock springs then measure them. If not the order stock ones, they're listed on most sites.
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P.
1993 YJ - Stock 2.5L, Scrapped. R.I.P.
gunnorthered is offline
post #3 of 4 Old 08-05-2009, 01:47 PM Thread Starter
fishmanwill
1987 YJ Wrangler
The springs are stock. The shackles are homemade, my brother and I made them from 3/8" x 2" flatbar. They are original dimensions just beefier. So I thought I should replace all the bushings while I was working on the suspension. Thanks,
Will
1987 Wrangler
post #4 of 4 Old 08-05-2009, 02:15 PM
gunnorthered
The jeep will flex easier with polyurethane bushings. Go to 4wd.com, they have kits for the springs that include bushings, sleeves, and bolts.
Spring Bushings shunt YJ Wrangler Technical Forum 5 03-06-2008 10:27 PM
leaf spring bushings redjeep669 YJ Wrangler Technical Forum 4 11-18-2007 02:09 AM
HELP!..cant find right spring bushings 1984cj7tbi350 YJ Wrangler Technical Forum 8 06-12-2007 10:50 PM
BDS Spring Bushings? UPnOVER YJ Wrangler Technical Forum 6 10-02-2003 10:02 AM
BDS spring Bushings???? UPnOVER YJ Wrangler Technical Forum 1 09-16-2003 09:30 AM
