spongy clutch - JeepForum.com
post #1 of 8 Old 06-04-2013, 12:27 PM Thread Starter
jhrebs
1987 YJ Wrangler
spongy clutch
So recently I noticed I have to floor the clutch to shift. Never done this before. So checked the fluid and whatta ya know... bone dry. Gonna fill and bleed tonite but I have never noticed a leak. Is it possible to just go through fluid without a leak? Have to admit with all the work I have done to the jeep I never checked the clutch fluid. So not sure how long it has been low.
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 8 Old 06-04-2013, 01:14 PM
Siva283
If it is dry its leaking somewhere. Probably just a slow leak. You should check around the bellhousing really well. Unless it was modified you have an internal slave and the are notorius for going bad.
Ask me how I know...
Siva283 is offline
post #3 of 8 Old 06-04-2013, 02:25 PM
remmons
X2. These have the internal slave cylinder which have been known to leak without ever knowing.
Robert.
remmons is offline
post #4 of 8 Old 06-04-2013, 03:13 PM
pasinbuy
Also check the Master cyl. The MC leaks inside of your rig. Feel the fire wall behind the clutch pedal and up for wetness.
pasinbuy is offline
post #5 of 8 Old 06-04-2013, 03:52 PM
jserna
1987 YJ Wrangler
That is what I was going to say. I pulled out my floor mat and it was damp. Slowly leaked out of the piston.
jserna is offline
post #6 of 8 Old 06-04-2013, 04:08 PM Thread Starter
jhrebs
1987 YJ Wrangler
So no way there is an internal leak of some sort? If it is leaking it must be visible? Sorry for the ignorance, this is a whole new realm for me.
jhrebs is offline
post #7 of 8 Old 06-04-2013, 04:32 PM
killakeane
1987 YJ Wrangler
Had the same issue, i didn't ever catch a leak - but my clutch was shot for the most part. the internal slave ended up going.
killakeane is offline
post #8 of 8 Old 06-04-2013, 05:36 PM
idaholtby
You have an obvious hydraulic issue. If the floor board is wet where the push rod from the clutch pedal meets the master cylinder at the firewall, then your Master cylinder is bad. If this is the case, the replace the master and bleed the system. Start budgeting though for a slave replacement. The Slave will fail soon after a master failure. Some what due to them having equal lifespans, but then it is accelerated when the master goes sour as it sends debris south down the line to the slave.
idaholtby is offline
