Spongy brakes/no brakes - JeepForum.com
post #1 of 14 Old 06-22-2013, 08:15 PM Thread Starter
killakeane
1987 YJ Wrangler
Hey, i replaced my brake hose today, and bled the brakes numerous times on each side as well as gravity bled them. The brakes feel really strong when the jeep is turned off but as soon as it starts running the brakes go basically dead and too the floor. i can't figure out what's doing it considering the amount of times i bled them. any input?
Staten Island, NYC
87YJ 4.2L 5 spd with some cool stuff done to it.
ΜΟΛΩΝ ΛΑΒΕ
US Navy Jeep Club Hull# 231
Maritime Offroading Club
killakeane is offline
post #2 of 14 Old 06-22-2013, 08:29 PM
TSEJEEPERS
Any leaks when you pump the brakes?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 14 Old 06-22-2013, 08:33 PM Thread Starter
killakeane
1987 YJ Wrangler
None, at least none visible. I had a leaky hose that's why I replaced that. The master was fine prior to my hose leak so I don't believe it's the master either.
Staten Island, NYC
ΜΟΛΩΝ ΛΑΒΕ
post #4 of 14 Old 06-23-2013, 01:19 PM Thread Starter
killakeane
1987 YJ Wrangler
Anyone know what's wrong with it?
Staten Island, NYC
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 14 Old 06-23-2013, 01:24 PM
PA_YJ19
Sounds like a bad booster if ur pedal is dropping to the floor. There's probably a leak in it sumwhere... It holds air so u won't physically see it, have sumone push the pedal down and put ur head by the booster. If u hear ne whistle type noise or air escaping newhere then it's not doing its job. When u press the pedal down u should feel the pressure build up not release, as it sounds like its doing in ur case.
PA_YJ19 is offline
post #6 of 14 Old 06-23-2013, 01:42 PM Thread Starter
killakeane
1987 YJ Wrangler
i don't think its a leak, wouldn't i be loosing fluid from the mc?
Staten Island, NYC
ΜΟΛΩΝ ΛΑΒΕ
post #7 of 14 Old 06-23-2013, 01:51 PM
pasinbuy
What all did you do to your brakes other than the hose?:
pasinbuy is offline
post #8 of 14 Old 06-23-2013, 02:10 PM
jhrebs
1987 YJ Wrangler
There is a rare chance that the MC could have gone. Yes it did work before you did your line, but maybe a new line, bleeding alot......YJ's are old and temperamental. I would guess booster or MC, only by process of elimination
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #9 of 14 Old 06-23-2013, 02:10 PM
PA_YJ19
Not if it's the booster, the booster just holds air. Ur master holds the fluid.
PA_YJ19 is offline
post #10 of 14 Old 06-23-2013, 06:28 PM Thread Starter
killakeane
1987 YJ Wrangler
was talking to my uncle who used to work on cars a lot, he said it's not the booster if it were the booster it would be hard at all times both running and while off, i also talked to my fiances father, who has ground up a few jeeps hot rods etc and he thinks it might be the shoes in the back, ill try rebleeding as well as adjusting the rear shoes with the spoon? i believe thats what it's called - not sure - this will be my first time doing it. i'll let ya'll know what the outcome is when i figure it out, and if i don't well i'll be referring to the forum for more details. thanks for the input so far gents.
Staten Island, NYC
ΜΟΛΩΝ ΛΑΒΕ
post #11 of 14 Old 06-23-2013, 06:37 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If the master cylinder 'sucked air' it now has to be bench bled or you will never get brakes to bleed.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #12 of 14 Old 06-23-2013, 06:40 PM
TSEJEEPERS
Not harping on the leak thing but, clean off the area where you put the new hoses on. Where the hose connects to the hard line and the caliper.
Have someone pump the brakes up. Pump it 3 times then hold. If there is any evidence of brake fluid there is a leak.
post #13 of 14 Old 06-25-2013, 05:13 AM
Dewster196
Which way did you bleed the brakes, you are supposed to start at the bleeder furthest from the master and work to the closest. Just a thought.
A Nation of Sheep Breeds a Government of Wolves!
Dewster196 is offline
post #14 of 14 Old 06-25-2013, 08:59 AM
jay-h
It's normal, if you have bled off the vacuum of the booster, for the pedal to lower when the engine starts. This is the result of the booster becoming active. Obviously shouldn't go all the way to the floor however, but the usual failure mode of boosters is vacuum leak which would manifest itself in a higher (unboosted) pedal position.
Edited to add: What you are feeling when the vacuum is bled off is the ACTUAL pedal and free play. If that is solid, you do not have a bleeding issue. Once vacuum is applied the servo mechanism allows some degree of travel and converts that travel to valve boost against the master cylinder. The normal mode of failure for boosters is vacuum leak, but if you can shut off your engine and go back 20 minutes later and still have vacuum boost, you don't have much leak.
Mine has a significantly different position from vacuum to no vacuum, actually more that I'd like, but it has always been that way. I don't know if wear on the servo can cause excessively low travel, or that's just the way it is designed... I've never heard a discussion of servo wear other than vacuum leaks.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
brakes , help needed , no brakes , soft brakes
