spit, sputter, pop..........? - JeepForum.com
post #1 of 5 Old 11-28-2011, 05:20 PM Thread Starter
d5string
I have a 90 2.5 YJ with manual tranny. I went wheeling Sat at Uwharrie, and I was getting aa slight miss every now and then and just ignored it thinking maybe some bad fuel.
Well as I went on wheeling it got worse, and eventually it would do it on every incline, and when it was under any kind of load. It even died a few times. It will idle fine for as long as I will let it, but under a load it starts the sputter/pop.
I am torn between pulling the tank, and replacing the crank position sensor.
function over fashion
OIIIIIIO
d5string is offline
post #2 of 5 Old 11-28-2011, 07:20 PM
johnny27030
Have you checked your fuel pressure? Ide do that before pulling the tank. Pull your plugs and check to see if they are running lean (end of plug will be light colored or white) or rich (black). Let us know what you find.
johnny27030 is offline
post #3 of 5 Old 11-28-2011, 09:59 PM Thread Starter
d5string
The crazy thing is that I went out and ran it through the woods tonight, and it is running great. I climbed tree stumps, hills and everything I could to get it to miss and sputter, and it ran fine
OIIIIIIO
d5string is offline
post #4 of 5 Old 11-28-2011, 10:14 PM
johnny27030
It could be the ignition coil breaking down. After it gets hot it starts to lose its spark
post #5 of 5 Old 11-29-2011, 07:27 PM Thread Starter
d5string
I am leaning toward a fuel delivery problem, but now it will not do it
OIIIIIIO
d5string is offline
Spit Sputter after Nutter / Rush GA05SPORT YJ Wrangler Technical Forum 57 05-21-2011 05:26 PM
94 with 2.5 likes to spit, sputter and die. Advice? College94YJ YJ Wrangler Technical Forum 16 01-11-2011 03:22 PM
Spit, sputter, backfire... weirdodaddy YJ Wrangler Technical Forum 6 01-03-2011 10:54 AM
Hesitation, Spit & Sputter emschris TJ Wrangler Technical Forum 6 05-13-2005 08:30 PM
2001 TJ spit, sputter, won't run abermacks TJ Wrangler Technical Forum 0 06-19-2004 08:27 PM
