Spilling Gas?? - JeepForum.com
post #1 of 11 Old 04-12-2007, 11:36 AM Thread Starter
Ripcurlsurfin96
Spilling Gas??
Im not quite exactly sure if this should go into general discussion or tech so i thought it fit better here:
I just recently bought a YJ and everytime i go to fill it up it doesnt automatically cut off when the tank gets full... It wants to continue to "fill" the tank and overflow everywhere... Any idea as to why this is happening? I try to put the nozzle as far in as possible but it never fails to overflow... Thanks for the help in advance~!
Ripcurlsurfin96 is offline
post #2 of 11 Old 04-12-2007, 11:40 AM
Think
Think's Avatar
have you tried filling at more than one station? seems pretty obvious, but sometimes the simplest things make a difference.
the shutoff function usually has to do with the fuel nozzle, at the backpressure going in to the little hole under the nozzle is what shuts off the pump.
that being said, I would look at your lines to the tanks to make sure there are no crimps or blockages that could make the gas barf out like that.
95 YJ 2.5 litre + broke student with a TON of debt = slightly more than stock Jeep that is rusting out
I'm not a vegetarian because I like animals, I'm a vegetarian because I hate plants
Think is offline
post #3 of 11 Old 04-12-2007, 11:51 AM Thread Starter
Ripcurlsurfin96
Ya i did try multiple stations... But i will check to see if there are any crimps in the line.. Does the filler hitting the tailight have anything to do with it maybe? sorry maybe a dumb question but if it isnt sealing all the way the backpressure is not going into that little hole....??
post #4 of 11 Old 04-12-2007, 12:25 PM
mmontec_ss85
My 95 yj refuses to trip the gas nozzle when filling up. It does not matter which station I use, so I stand there and listen. I just live with it.
mmontec_ss85 is offline
post #5 of 11 Old 04-12-2007, 12:28 PM
FSTG60MAN
happens to me all the time
sold the zj back in a yj, skyjacker 7000 absorbers, bfg 31x10.5x15 all terrains, hella lighting, highlift and more tow straps than god.
FSTG60MAN is offline
post #6 of 11 Old 04-12-2007, 12:40 PM
Ferrick
Ferrick's Avatar
Just another endearing quirk. Learn to live with it.
Ferrick is offline
post #7 of 11 Old 04-12-2007, 01:07 PM Thread Starter
Ripcurlsurfin96
Thanks alot. Its not a big deal, i was just curious.. Guess i got a few things to learn about my jeep
post #8 of 11 Old 04-12-2007, 01:24 PM
jeepnmike
jeepnmike's Avatar
Its not fun when your standing right next to nozzle, daydreaming, and then all of a sudden it clicks and before you know what happened your pants are suddenly wet. Its always nice driving home reeking of gasoline
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #9 of 11 Old 04-12-2007, 01:33 PM
award
I had that problem on my Grand Cherokee 4.7 V8 Overland. The garage dropped the tank and fitted a new seal & it's been fine since. Andy, Manchester UK.
award is offline
post #10 of 11 Old 04-12-2007, 04:57 PM
jeepinjc
jeepinjc's Avatar
Happens all the time to me, I just hold my lighter under the jeep to burn up any gas that spills out before it goes all over the ground
(Just kidding
Blue 93' YJ, 4.0, 5spd, skyjacker 4" lift, crager simulated beadlocks w/33" bfg muds, skyjacker swaybar disco's, dana 30/35 w/ 4:10's, skyjacker t-case drop, and many mods to do yet
Jeep Drivers who dig COUNTRY music member #13
jeepinjc is offline
post #11 of 11 Old 04-12-2007, 06:40 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
mine is like that also, but i also get a special little surprise, if i fill up, and then only drive like 4 miles back home, then the next day i notice a few drips under the gas cap...take it off, and i have niagra falls under pressure come rolling out the back, usually a good gallon or two, i think it may be the heat, plastic tank, and then when the sun hits it the gas expands quicker than the tank.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
Gas spilling over when filling jimaug87 TJ Wrangler Technical Forum 734 02-23-2013 07:18 PM
Spilling Gas calpbs YJ Wrangler Technical Forum 4 07-05-2010 08:06 PM
Spilling out gasoline from line under hood. penknife YJ Wrangler Technical Forum 2 11-21-2009 03:09 PM
Problem: Gas spilling out when filling up DjPiLL TJ Wrangler Technical Forum 27 10-13-2009 08:14 PM
Why is coolant spilling from this hole Mr. Tobes YJ Wrangler Technical Forum 6 05-22-2006 11:04 PM
