speedometer problems - JeepForum.com
post #1 of 6 Old 05-10-2011, 07:17 AM Thread Starter
uncdude420
i was wondering if somebody on here could help thru hooking my speedo back up, i have a 92 6 cyl.. i was told that i just have to run a wire back to the plug on my tranny, but there is 3 wires, and i have no idea which one it goes to, or if that is all i have to do, i would appreciate any help i get, thanx
uncdude420 is offline
post #2 of 6 Old 05-10-2011, 12:42 PM
MJMPC
What is wrong with your speedo ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 6 Old 05-10-2011, 02:10 PM
Brumble83
You should have three wires running back to the speedo.
Brown/red (ground)
White/black (8 volt)
Blue (5 volt)
Brumble83 is offline
post #4 of 6 Old 07-01-2011, 07:28 PM
57mtrfxr
Question on voltage at t/c
Using my multi meter I get the 5 volts from the blue but not the 8 volts on the white wire. I pulled the cluster out and it really looks pretty good. Can i assume I have a bad connection soemwhere on the white wire? WHre does the 12 volts originate from?
92 YJ 4.0 manual 2 in body lift, saving up for 2.5 in Old Man Emu lift. 31x10.5x15 BFG A/T. Ivault center console w/kenwood stereo
57mtrfxr is offline
post #5 of 6 Old 07-02-2011, 05:58 AM
Alfons
The wires you need will be coming from the speed sensor attached to the transfer case and not the transmission.
Alfons is offline
post #6 of 6 Old 07-02-2011, 06:13 AM
mike_breaker_5
what occurred just prior to the loss of the speedo? sye install, x-case out for some reason, mouse found a good warm spot next to your pcm to build a nest, or did it just decide to stop working one day? some lead up details would help diagnoses easier.
sounds like you had it unhooked purposefully for some reason by the way your first post reads. if you had the VSS module out of the x-case you may just have the unit indexed wrong in the hole, not allowing it to interface the gear on the output shaft. but as others said the speedo reading comes from there at your x-case and not the trans.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
speedometer problems....? fishmanwill YJ Wrangler Technical Forum 6 04-06-2012 07:54 AM
A couple problems.. help. (heater and speedometer) Runnin87 TJ Wrangler Technical Forum 4 01-03-2008 04:52 PM
Speedometer problems chiqo YJ Wrangler Technical Forum 4 04-12-2004 11:34 PM
speedometer problems with SYE install gjohnson YJ Wrangler Technical Forum 3 02-10-2004 10:06 PM
Speedometer problems Jeep_YJ YJ Wrangler Technical Forum 2 02-10-2003 03:16 PM
