Speedometer Plug ? - JeepForum.com
post #1 of 4 Old 11-15-2008, 11:54 AM Thread Starter
thejones101
Speedometer Plug ?
So I pull my instrument cluster to see if I can get my speedo working and I see a small round plug hanging there with nothing to plug it into. My guess would be that it is suppose to plug into the back of the speedometer but there is no hole that it would fit into. I am missing something here?
thejones101 is offline
post #2 of 4 Old 11-15-2008, 02:39 PM Thread Starter
thejones101
I am wondering if there is a male or female plug on the actual speedometer that the round wire plugs into?
Thanks in advance
post #3 of 4 Old 11-15-2008, 08:14 PM
bunkrdfool
Im pretty sure there is only one plug, and it plugs into the tachometer, and everything runs off of that one. But im not really sure because my speedometer doesnt work either
USAF Security Forces. Keeping your chair safe since 2009.
bunkrdfool is offline
post #4 of 4 Old 11-16-2008, 06:52 AM Thread Starter
thejones101
Yeah mine looks the same but there are two plugs directly behind the speedometer just hanging there...I'm guessing they have to go to something.
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
speedometer plug in on 92 4.0 acat YJ Wrangler Technical Forum 6 08-12-2009 06:01 PM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
Speedometer Gear Plug Leaking? newgene TJ Wrangler Technical Forum 15 07-06-2005 08:14 AM
HVAC fan inop except on High, found the wiring & plug fried... need plug. Jerry Bransford TJ Wrangler Technical Forum 18 02-21-2005 02:44 PM
