speedometer not working - JeepForum.com
post #1 of 2 Old 09-01-2011, 04:13 PM Thread Starter
parpac316
parpac316's Avatar
My speedometer on my YJ does not work. When I come to a stop and push the clutch in fairly quickly before I do, my jeep will die. If I keep it in gear as long as possible before coming to a stop most of the time it will not die. The gear in the transfer case looks fine. I have changed the sensor and lined it up correctly according to tire size. Today I tried a different cluster and still nothing from the speedometer. Any suggestions into what else I can do?
parpac316 is offline
post #2 of 2 Old 09-01-2011, 04:17 PM
Que89YJ
Use a drill and hook it up to the sensor and spin it. I know you said it was lined up but it sounds like it's not clocked correctly.
Que89YJ is offline
speedometer not working flipit13 YJ Wrangler Technical Forum 16 11-29-2014 01:14 PM
Speedometer not working Mikey1234 YJ Wrangler Technical Forum 8 12-16-2009 05:57 PM
Speedometer not working w9kh_kevin TJ Wrangler Technical Forum 3 10-19-2009 07:17 PM
Speedometer Not Working USMC SouthernYJ YJ Wrangler Technical Forum 9 07-19-2008 10:30 AM
Speedometer not working in 98 hscrugby TJ Wrangler Technical Forum 3 04-22-2008 01:55 PM
