speedometer not working - JeepForum.com
post #1 of 17 Old 05-10-2010, 08:25 PM Thread Starter
flipit13
well as the title states the speedometer isnt working or light up. i checked the transfer case but there is no spot for the speedometer cable by the tail.
only thing on the transfer case was 4 vacume lines. question is if it doesnt light up could it electrical.
thanks again in advance
rick
flipit13 is offline
post #2 of 17 Old 05-11-2010, 03:59 AM
Mark05059
the drivers side of the transfer case... in the tail shaft section is where the speedometer gear adapter is. If I can recall yours should be an electric speedometer and not have a cable.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 17 Old 05-11-2010, 05:23 AM
crazyquadder
If it doesn't have lights it could just be the light just happened to go out. They are on different wires and everything. Check and see if there is power to the sender
crazyquadder is offline
post #4 of 17 Old 05-11-2010, 05:40 AM
Que89YJ
The lights and speedo are 2 seperate circuits and 2 different issues. X2 on the location of the VSS on the tailshaft. Check for faults. The VSS is an input to the ECU and should blow a fault if its not working.
Que89YJ is offline
post #5 of 17 Old 05-11-2010, 06:02 AM
muddy93
1987 FSJ Wagoneer
Dose your odometer work?
When I first got my '93, both the spedo and odometer were not working. I checked the speed sensor, and traced all the wiring back to the ECU, and then up to the dash. All the wiring was fine, but what I found was a burnt out trace in the printed/ribon circuit that is behind the gauges. The burnt trace was one that supplies constant + to the gauge. I was able to get the spedo working by simply making a jumper wire and running it from the posative terminal on the tach, to the positive terminal on the spedo.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #6 of 17 Old 05-11-2010, 06:08 AM
Que89YJ
Thats another one to bookmark Muddy93. Ive never heard of that either! The ECU would still get a signal that way. What other indicators didnt function with the B+ trace open? Thats a good one to know.
Que89YJ is offline
post #7 of 17 Old 05-11-2010, 06:17 AM
muddy93
1987 FSJ Wagoneer
Que89YJ,
In my case, the trace was burnt just before the spedo connection, so the only gauge that didn't work was the spedo/odometer. If I remember correctly, there are two ribon circuits, one for the spedo and tach, and another one for the rest of the gauges. Depending on where the brake was located though, it could effect multiple gauges, only one gauge, or all of them. It's one of those things where you'd just have to pull the gauges, and check it out, and make repairs as needed.
muddy93 is offline
post #8 of 17 Old 05-11-2010, 09:07 AM Thread Starter
flipit13
thanks tons guys
that is the only gauge not working so thats a plus. i will check this weekend since it is at my friends garage.
as for checking the codes i dont have my meter anymore i forgot how to read
i know through ignition on off back on right?
been awhile lol
thanks tons
rick
flipit13 is offline
post #9 of 17 Old 05-11-2010, 09:07 AM Thread Starter
flipit13
no my odometer doesnt work
flipit13 is offline
post #10 of 17 Old 05-11-2010, 09:18 AM
muddy93
1987 FSJ Wagoneer
Originally Posted by flipit13 View Post
thanks tons guys
been awhile lol
thanks tons
rick
To check the codes using the ignition,
turn the key ON, OFF, ON, OFF, ON, and then cound the number of times that the CHECH ENGINE light flashes.
NOTE: The first time I tried to get codes this way, I couldn't get it to work. Aparantly if you go through the on, off, on, off, on sequense to fast, it will not flash the codes. Once I slowed down a bit, it flashed the codes just fine.
The light will flash, and then pause, and then flash again;
EXAMPLE, code 55 will be displayed as "flash, flash, flash, flash, flash" pause "flash, flash, flash, flash, flash". Then there will be another pause, and the next sequense of flashes will begin. I found it helpfull to write down the number of flashes, so I didn't have to try to remember them wile I looked them up online.
muddy93 is offline
post #11 of 17 Old 05-11-2010, 09:41 AM
MJMPC
Here ya go
OBDI Error/Check Engine Codes - JeepForum.com Community Jeep Wiki
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #12 of 17 Old 05-15-2010, 06:44 AM Thread Starter
flipit13
thanks alot guys today i am at the jeep and have a few projects to get done.
so let the games begin...
flipit13 is offline
post #13 of 17 Old 05-15-2010, 10:32 AM
Dhofstet
1973 KK Liberty
bust out your cell phone, use the video cam to record the flashing so you can easily record/remember how many times, and if there were any flashes.
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
post #14 of 17 Old 09-28-2012, 02:39 PM
JCHoppa
Speedometer Not working 1994 Jeep yj
I need Help with my speedometer in my 1994 Jeep yj that has been converted to a ford 302. I bought the jeep a few months ago and have been driving withought a speedo sense. finally got around to fixing. Purchased a new speed sensor and still nothing. all wires are in place and have power to the sensor. Tried to test the new speed sensor but couldnt seem to figure out how to test. the wires have all been replaced by PO so i have no clue what wires are suppose to go were from the plug ( Solid orange, Grey with white stip, black with blue strip). I wonder if i should just go aftermarket?? any help would be GREAT!!
JCHoppa is offline
post #15 of 17 Old 09-28-2012, 07:27 PM
Mark05059
repost this in its own thread
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Speedometer Not Working!!!! Help Ohio Jeep TJ Wrangler Technical Forum 8 02-20-2007 08:38 AM
Speedometer not working Cross Eyed TJ Wrangler Technical Forum 1 01-31-2006 05:06 PM
Speedometer not working UltimatE YJ Wrangler Technical Forum 2 02-28-2005 06:22 PM
Speedometer not working Galvoknight YJ Wrangler Technical Forum 9 08-15-2003 06:30 PM
speedometer not working RenegadeYJ17 YJ Wrangler Technical Forum 1 11-13-2002 12:50 PM
