Speedometer gears for pre-92 YJ - JeepForum.com
post #1 of 22 Old 03-18-2008, 08:07 AM Thread Starter
Matt_vs_YJ
I hope this little bit of information is helpful to someone here. I had some trouble finding the correct speedometer gear for my '89 with the cable-driven speed. The long-shaft style gear is not stocked at Quadratec and can be tough to find at Jeep dealers. I didn't want to convert to an electronic sender, though that is an option.
Thankfully there is another, and usually cheaper, option. Many Mopar trucks and muscle cars used the exact same gears. I was able to find one on eBay for $15. Compared to the original Jeep gear, the shaft is identical. Search for "mopar speedometer gear" on eBay and you'll see a half dozen or so, most of which will fit. Yearone and other Mopar muscle restoration companies have them as well. Look for ones that fit the 727, 883, 904, and 998 transmissions to start.
I'll try to find some Mopar part numbers. If anyone else knows them please post.
Thanks, Matt
Note: I'm talking about the long-shaft speedometer gears for cable-driven speedometers, not the newer short-shaft style for electric speedos. There was some overlap in years where some cable-driven speedos used short-shaft gears, and vice versa.
Matt_vs_YJ is offline
post #2 of 22 Old 03-18-2008, 09:23 AM
swa240z
Matt - interesting find. I have had a speedo gear on backorder from the dealer for 6 months now. Which gear did you buy and where did you get it?
I need a gear for 33's and 4.11 gears. Some charts show a 35 tooth and some show a 36 tooth. I'm not real sure which is the right one.
Steve
Yellow 2000 TJ, 4.0L, NV3550, 3.73 gears. 4" RC X-series lift, 33x12.50x16 MT MTZ's on 16x10 MT Classic Bead Locks. Bumpers, winch, axles and gears coming soon.
./l ,[_\_\ ],
l---L –OlllllllO-
()_) ()_)--o-)_)
swa240z is offline
post #3 of 22 Old 03-18-2008, 11:42 AM
Berb_15
Yea I had a speedo gear on backorder for a ridiculous amount of time with two companies, finally I bought one off ebay, came in less than a week
"Lock tite!!
Mans best friend cuz your dog won't keep your jeep from falling apart."
Berb_15 is offline
post #4 of 22 Old 03-18-2008, 03:52 PM
J33Pyj
If anyone need i have an extra speedo gear for 33's with 4:88 gears it's a 41 tooth.
90 yj/ 4:88 gears/33x12.50x15 Super Swamper TRXUS Mud Terrains/K&N air system/2.5L/D30front aussie equip'd/D35 rear / 3in BL/ 2in shackle lift / XRC8 Winch
If you havent broken it, you havent been wheelin
J33Pyj is offline
post #5 of 22 Old 03-18-2008, 05:32 PM Thread Starter
Matt_vs_YJ
Look at eBay item number 280209174462. That's the one I got.
I got a 35 tooth and I have 32's and 4.10 gears. So far it seems right, but I haven't checked it against a measured mile yet. According to Quadratec you'd need a 34 tooth for 33's and 4.11.
post #6 of 22 Old 03-18-2008, 05:34 PM Thread Starter
Matt_vs_YJ
Which is also, by the way, the stock gear for 4.10 axles. So if you run 33's and re-gear to 4.88, just leave it alone and it'll be right.
post #7 of 22 Old 03-18-2008, 07:19 PM
swa240z
That's exactly my problem. This site shows the 36 tooth gear (which has supposedly been verified by GPS) for 33" and 4.11.
EDIT: I just checked the Quadratec chart and it actually shows a 36 tooth gear (NOT the 34 tooth) for 33's and 4.11's. I'd say the 36 tooth gear is a winner. Now I just have to find one.
EDIT 2: Found the gear I needed on ebay and it's on the way.
Steve
./l ,[_\_\ ],
l---L –OlllllllO-
()_) ()_)--o-)_)
swa240z is offline
post #8 of 22 Old 03-18-2008, 09:53 PM Thread Starter
Matt_vs_YJ
Odd... both those sites are different from what printed in the latest Quadratec catalog.
Either way, I'm glad you were able to find the one you need.
post #9 of 22 Old 03-19-2008, 07:17 AM
lah2420
This help?
Here's a list I compiled a while back of part numbers from the dealer. They call it a Chrysler Pinion Gear.
Teeth Color Part Number
24 WHITE 3410024
25 BLUE 3410025
26 RED 2538926
27 WHITE 52068149
28 BLUE 52068150
29 BLACK 52068151
30 YELLOW 52068152
31 GREEN 52068153
32 BLACK 52068154
33 YELLOW 52068155
34 GREEN 52068156
35 ORANGE 52068157
36 RED 52068158
37 WHITE 52068159
38 BLUE 52068060
39 GREEN 52068061
40 ORANGE 52068062
41 RED 2538941
42 WHITE 2538942
43 BLUE 2538943
lah2420 is offline
post #10 of 22 Old 03-19-2008, 07:37 AM
swa240z
I'm constantly looking at that catalog and I never even noticed that chart. Kind of strange that there is a difference between the catalog and the website. I think the GPS verified charts are probably the best way to go given all of the differences in charts, but not all combinations on the chart I used had been verified by GPS.
My new gear should be here this weekend so I can double check the speedo accuracy. Maybe we need a JeepForum chart of CONFIRMED speedo gears for a given tire size and gear ratio.
./l ,[_\_\ ],
l---L –OlllllllO-
()_) ()_)--o-)_)
swa240z is offline
post #11 of 22 Old 03-19-2008, 09:07 AM
leedurr
leedurr's Avatar
1987 YJ Wrangler
Well I tried the 35 tooth with 33's and 4.10's and it is still off. I went from 3.07's with 31's. It took me 3 weeks to get it from Dodge. they quit making them. i know when I am doing 18 on the speedometer I am actually doing 15 according to the base police....lol. i am looking for a 36 tooth gear now.
Lee
87 YJ, 4.5 RE lift with monotube RE shocks, 33 LTB's, 258 w/4.0 head, HEI, and Weber carb, Header, Comp 252H cam, Dynomax, cat back and much more.......
leedurr is offline
post #12 of 22 Old 04-06-2008, 11:15 PM
hoki06
Sorry to bring back an old thread but I'm wondering what tooth gear I'll need for 36s with 4.88s. And where would I find one?
hoki06 is offline
post #13 of 22 Old 04-07-2008, 12:06 AM Thread Starter
Matt_vs_YJ
There's a good write-up here.
There's an easy formula that I found: Old wheel diameter x old Speedo gear teeth, divide by new wheel diameter = teeth on new gear
Here's a chart that seems to agree with most of the others I've seen.
post #14 of 22 Old 04-07-2008, 01:31 AM
flame0086
I almost thing this sould be stickied, or a link added to the FAQ. Its a question not asked a lot, but deffinately a useful thread.
flame <--- waiting for new axles and gears before buying a new speedo.
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #15 of 22 Old 04-08-2008, 07:12 PM
1orangejeep
1987 YJ Wrangler
I understand the gear situation, but what about a new speed-o cable. Seems no body has them and mine is broke. Any suggestions as to were to get one? Thanks
1orangejeep is offline
Speedometer Gears jmalys TJ Wrangler Technical Forum 1 03-20-2009 12:03 AM
Speedometer Gears DCal12 TJ Wrangler Technical Forum 37 08-30-2007 10:08 PM
Speedometer Gears...?? Cone YJ Wrangler Technical Forum 17 06-26-2007 02:47 PM
speedometer gears Ozzy817284 TJ Wrangler Technical Forum 3 01-24-2007 01:47 PM
Speedometer Gears? TEXASRAM YJ Wrangler Technical Forum 4 06-08-2004 03:18 PM
