Speedometer gear troubles - JeepForum.com
post #1 of 3 Old 04-08-2010, 03:26 PM Thread Starter
InEmberClad
Alright so, I need to replace my speedometer gear and I'm having several issues.
One, I can't get the old one out. Do I need special tools?
2. I'm running 31x10.5 tires with 3.73 rear axle ratio. I used the chart on jeep4x4center.com and it says I need a gear with 33 teeth.
I called the dealership and they said they have 2 sizes of gears, .75in diameter and 1.5in diameter. Only the 1.5in ones come with 33 teeth, but that definitely won't fit in my car.
I can't just order the one off of the website because it says its for 91-95 jeeps with electronic speedos and mine is an 89 with a cable driven speedo.
Does anybody know what kind of gear I need to get and where I can find one?
Thanks
InEmberClad is offline
post #2 of 3 Old 04-08-2010, 03:43 PM
gtstricky
look here (bottom chart): Jeep Parts, Jeep Accessories & Jeep Soft Tops From The Jeep Parts Experts - Quadratec
and I think this is the actual gear: http://www.quadratec.com/products/55200_6033.htm
Must reads for new TJ Owners:
gtstricky is offline
post #3 of 3 Old 04-08-2010, 04:20 PM Thread Starter
InEmberClad
Thanks you rock!
Speedometer Gear... gseale TJ Wrangler Technical Forum 10 04-18-2009 06:04 PM
4th gear troubles Jeepinjon YJ Wrangler Technical Forum 3 11-27-2006 04:55 PM
steering gear troubles?? fatjeepguy300 TJ Wrangler Technical Forum 1 07-02-2006 09:32 AM
2nd gear troubles Brudmike7 YJ Wrangler Technical Forum 6 11-12-2004 07:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
