Speedometer gear too small? - JeepForum.com
post #1 of 6 Old 02-23-2014, 12:15 AM Thread Starter
YJ4LIFE
So I got a 28 tooth speedometer gear with the long shank but I think the diameter is too small. Am I suppose to change the matching gear in the transmission? It seems to be 1/2" too small or 1/4" per side.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #2 of 6 Old 02-23-2014, 12:21 AM
stenyeart
It is right. They vary in diameter based on the number of teeth. It has to be clocked correctly to make contact with the gear inside the transfer case.
stenyeart is offline
post #3 of 6 Old 02-23-2014, 06:12 AM
nagel
I have the same issue, and although I haven't tackled the issue yet, I've been told you may have to swap over both gears (meaning the one on the inside as well). I swapped a NP242 in for an older NP231, and needed to use the 91 VSS from the NP231 (so I had both electronic and cable). The gears on the original speed sensor from the 242 are larger, and no amount of adjusting has gotten the smaller 91 VSS to mesh. Supposedly I have to open the 231 and take the corresponding gear and swap that over too..
nagel is offline
post #4 of 6 Old 02-23-2014, 11:07 AM Thread Starter
YJ4LIFE
I did a few searches last night and finally understand what to do. The housing is eccentric like a cam lobe.THAT is what I have to clock to bring the smaller gear close to the stock worm gear. Thanks!!!!
YJ4LIFE is offline
post #5 of 6 Old 02-23-2014, 01:28 PM Thread Starter
YJ4LIFE
I got the new gear to work but now my speedometer needle wabbels a bit why is that? Does it need more tooth contact?
YJ4LIFE is offline
post #6 of 6 Old 02-23-2014, 01:37 PM
medic-11
It might. There are 4 positions possible, the way the teeth fit into the grooves. It took me a few minutes to figure it out myself when I did mine last month.
medic-11 is offline
