Speedometer doesn't work! - JeepForum.com
post #1 of 12 Old 02-06-2010, 04:00 PM Thread Starter
newjeepusr
On to my next problem, my speedometer doesn't work. Everything other gauge on the dash works but the speedometer. I am guessing it is cable driven off of the transmission? Any input fellas, and or ladies?
newjeepusr is offline
post #2 of 12 Old 02-06-2010, 04:07 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No, there is no speedometer cable on your '94.
It is driven by an electrical VSS (Vehicle Speed Sensor) signal from the transfer case. Here is where it's located on the driver's.
The sender in this pic is from my '91 which does use a cable, but the sender for yours is in the same location.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 12 Old 02-06-2010, 08:55 PM
Mark05059
easy way to tell for sure if its working is take it out and use a cordless drill to spin it while watching the speedo gage. If it works with the drill.. you will need to have it "clocked" correctly to work
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 12 Old 02-06-2010, 09:21 PM Thread Starter
newjeepusr
So take the dash out and use a cordless drill on it? Really? In addition to the speedo gauge not working, the dash lights are also out.
post #5 of 12 Old 02-06-2010, 09:23 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
OP doesn't have a cable driven speedo.
Check all your fuses & connections to the gauges.
Max
Mean Max is offline
post #6 of 12 Old 02-06-2010, 09:23 PM
Fhajad
Um.
How does a drill send a VSS signal over a wire?
Fhajad is offline
post #7 of 12 Old 02-06-2010, 09:26 PM
MJMPC
No dont take the dash out for the speedo take th VSS out of the t-case and use a drill to turn the gear.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 12 Old 02-06-2010, 09:26 PM
rivalarrival
Stormaggedon
rivalarrival's Avatar
Install a GPS nav unit over the non-functioning speedometer.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline
post #9 of 12 Old 02-06-2010, 09:39 PM Thread Starter
newjeepusr
But, if it isn't a speedo cable... would that work?
post #10 of 12 Old 02-06-2010, 09:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I feel like an idiot. I envisioned spinning a cable at the speedo head. I was suffering from tunnel vision apparently.
THAT is exactly what he could do.
Yes, if you use a drill to spin the gear on the sender, it will generate a signal just as if the T-case was spinning it. If the sender is working properly, that is.
Max
Mean Max is offline
post #11 of 12 Old 02-06-2010, 09:54 PM
MJMPC
Trust us we didnt tell you wrong about your parkingbrake did we?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #12 of 12 Old 02-06-2010, 09:55 PM Thread Starter
newjeepusr
thanks, I will do it in the morning.
Speedometer and tachometer wont work Trueblood TJ Wrangler Technical Forum 1 03-31-2009 06:25 PM
Speedometer does not work! toberste TJ Wrangler Technical Forum 1 01-14-2009 08:57 PM
Speedometer won't work tbenne6 YJ Wrangler Technical Forum 6 05-04-2008 09:49 PM
speedometer doesn't work dlindberg YJ Wrangler Technical Forum 0 10-20-2007 12:08 PM
Thanks for the help. Speedometer doesn't work Now...... Aaron1 TJ Wrangler Technical Forum 0 07-18-2005 05:45 AM
