Speedometer cable leaking - JeepForum.com
post #1 of 22 Old 06-04-2013, 02:34 PM Thread Starter
GootsYJ1990
There is a leak coming from my speedometer cable under my dash. What could be causing it to leak?
"The only easy day is yesterday."
GootsYJ1990 is offline
post #2 of 22 Old 06-04-2013, 02:37 PM
Rproject
1987 YJ Wrangler
If it's from the dash area, it's either the cowl seal or your fresh air intake on the hood, but the fresh air intake usually leaks on the passenger's side. I'd go with cowl seal.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 22 Old 07-16-2013, 12:49 PM Thread Starter
GootsYJ1990
Bump.
Its still leaking cant figure it out. Started after I installed SYE. I used silicon to try and seal the speedo cable where it connects to T-case and it worked for a week then started to leak again. Any suggestions?
post #4 of 22 Old 07-16-2013, 01:12 PM
XJ93
There is no fluid transfer in that cable. What you have is a water leak under your windshield or a rusted windshield frame. Replace the cowl seal and report back.
XJ93 is offline
post #5 of 22 Old 07-16-2013, 01:31 PM
Old4X
1990 CJ7
Leaking what? Gasoline, transmission fluid, engine oil, gear oil, coolant, water?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 22 Old 07-16-2013, 01:35 PM
Rproject
1987 YJ Wrangler
Since it's from your speedometer cable, you might need to add some of this: http://kalecoauto.com/index.php?main...products_id=22
1996 White ZJ
Rproject is offline
post #7 of 22 Old 07-16-2013, 01:56 PM
bpounds
bpounds's Avatar
Aw come on, he said speedo, not blinkers. Let's get with the program!
snork
bpounds is online now
post #8 of 22 Old 07-16-2013, 02:00 PM
TomI
1978 CJ7
Come on now! We are supposed to mention the sale Auto Zone has on speedo cable fluid! Found on the same self and right beside the blinker fluid!
Tom I.
'78 CJ7 (A 360 V8 powered mixed bag of parts)
'80 CJ7 (98% original and gonna stay that way)
'12 CTD 3500 Dodge (Tow rig and daily driver)
'05 Western Star/Cottrell Auto hauler (Big tow rig and means of paying for the Jeep habit)
TomI is offline
post #9 of 22 Old 07-16-2013, 02:02 PM
TomI
1978 CJ7
Oh! I be too late! Sorry!
Tom I.
TomI is offline
post #10 of 22 Old 07-16-2013, 02:34 PM Thread Starter
GootsYJ1990
I have the older manual speedometer cable.
post #11 of 22 Old 07-16-2013, 02:36 PM Thread Starter
GootsYJ1990
Looking for serious answers please.
post #12 of 22 Old 07-16-2013, 02:41 PM
Rproject
1987 YJ Wrangler
You've already received serious answers, multiple times.
There is no "fluid" in the speedometer cable. If there is fluid "leaking" from the cable under the dash, then it has something to do with a water leak from either your cowl seal, your windshield or your fresh air intake.
You were asked what kind of fluid was "leaking", to which you gave no response.
Sorry to be a pr***, but when incomplete information is given, intelligent suggestions made, and logical questions asked without a response, sarcasm is the next logical response.
1996 White ZJ
Rproject is offline
post #13 of 22 Old 07-16-2013, 02:46 PM
Myjeep1986
Leak
As the others have said, check the seal at cowl, I would also check the grommet where the cable enters the firewall just left of master cylinder in picture-(slight chance water traveling through (water seeks easiest place in);
Myjeep1986 is offline
post #14 of 22 Old 07-16-2013, 02:48 PM Thread Starter
GootsYJ1990
Sure man. It's not water it's ATF fluid
post #15 of 22 Old 07-16-2013, 02:51 PM Thread Starter
GootsYJ1990
Didn't see the first questions about what was leaking sorry I just saw the the reply about blinker fluid.
