Speedo Issue - Page 2 - JeepForum.com
post #16 of 24 Old 09-03-2013, 06:10 PM Thread Starter
Rino1425
I went to the auto parts store today and looked at a brand new one from them. The spindle is centered just like on mine. I think im going to try a new gear to see if that helps.
Thanks again for all your help
Rino1425 is offline
post #17 of 24 Old 09-26-2013, 03:08 PM Thread Starter
Rino1425
So still working to figure this issue out, but while browsing quadratech today, i noticed something. They sell a "long shaft" speedo gear for the cable driven speedos. I am not sure if the transfer case i have is the original or not, but is it possible that it was set up for a cable drive and that is why its not working?
Rino1425 is offline
post #18 of 24 Old 09-26-2013, 07:22 PM
RstyXJ96
Transfer case is the same regardless of cable or electronic speedometer cable. You said that the drill test worked, that leads me to believe that either your gear isn't clocked right or your drive(n) (can never remember which is which) on the output shaft is broken. Did you look at the output shaft through the mounting hole for the VSS and look at the gear there?
RstyXJ96 is offline
post #19 of 24 Old 09-26-2013, 07:32 PM
rambo3489
My vote is it isn't clocked right if the drill trick worked. How do the teeth on the output shaft feel in there?
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #20 of 24 Old 09-26-2013, 07:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Speedo drive is clocked wrong.
Read post #27 in this thread.
http://www.jeepforum.com/forum/f12/s...-still-695330/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #21 of 24 Old 09-26-2013, 07:47 PM Thread Starter
Rino1425
I have turned the VSS all directions and still didnt work. I was able to feel teeth on the output shaft. If there is no difference between cable and electric, why is there different parts? Quadratec calls out a longer one for cable driven.
http://www.quadratec.com/products/55200_7105.htm
Rino1425 is offline
post #22 of 24 Old 09-26-2013, 07:56 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Jeeps from 1955-1992 used a speedo drive gear with a longer shaft design, and 1993-newer models use a shorter shaft design.
Although the speedo drive shaft design changed, the transfer case housing did not change.
Max
Mean Max is offline
post #23 of 24 Old 09-26-2013, 07:59 PM Thread Starter
Rino1425
I retract my statement regarding the longer one. After looking at the post Max, i will take everything back apart and measure. I can tell the transfer case has been taken apart at some point. I will also try to get a picture of the output shaft for you guys to look at.
Rino1425 is offline
post #24 of 24 Old 09-28-2013, 03:31 PM Thread Starter
Rino1425
Well that worked, All i had to do was clock it right and it works now. I never saw the marks on it, so when i tried to clock it before, i just rotated it 180*. It needed to be rotated about 10 more *.
Thanks for all your guys help
Jon
Rino1425 is offline
