Speedo. gear? - JeepForum.com
post #1 of 3 Old 04-26-2001, 02:39 AM Thread Starter
Tonka
2015 JK Wrangler
Speedo. gear?
Where can I get a speedo gear? I know that my speedo is off, and with me breaking lots o' stuff lately I cant afford any tickets. Any Idea on cost? slghtly modifyed 4 cyl 4.11's, 31's
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #2 of 3 Old 04-26-2001, 05:08 AM
jeffy
jeffy's Avatar
Go to the dealer. Actually first go to www.jeeptech.com and see what tooth count you need. Then go to the dealer and have them look it up. it will cost about $12 for the gear and under $1 for the O-ring. Get the O-ring just in case you pinch the old one. Takes only a few mintures to install if you know what you're doing. The hardest part is indexing the speedometer housing. But that's pretty easy once you know the numbers on the housing corespond to the tooth count. Just move the clip to the right numbers and bolt down. If it doesn't work then try rotating it some more.
*** www.4BangerJP.com ***
jeffy is offline
post #3 of 3 Old 04-26-2001, 11:29 AM Thread Starter
Tonka
2015 JK Wrangler
Thanks,jeffy, I need a 36 tooth speedo. gear.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
Take a speedo gear <> Leave a speedo gear spokanistan TJ Wrangler Technical Forum 1397 04-11-2017 08:41 AM
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
Changed speedo gear-Now Speedo no worky BoatCop TJ Wrangler Technical Forum 7 08-07-2011 04:37 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
Tire/Gear/Speedo Gear question about my 97 TJ SE Black Hole TJ Wrangler Technical Forum 6 05-10-2007 09:20 PM
