which speedo gear? - JeepForum.com
post #1 of 9 Old 11-14-2013, 06:57 AM Thread Starter
redneck23ms
which speedo gear?
which speedo gear do i need for 35's and 5.13s. its a 92 which should take the long speedo. is there a way to know whether it is the long or short that i need without tearing it apart? thanks
redneck23ms is offline
post #2 of 9 Old 11-14-2013, 07:15 AM
superj
the gear is just under the plug, right? it shouldn't be hard to look at.
as far as which gear, google and a diagram will show up showing which gears for what combo. its color coded for easy use
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 9 Old 11-14-2013, 10:50 AM
TheBootlegger
TheBootlegger is offline
post #4 of 9 Old 11-14-2013, 11:12 AM
baktie_91YJ
Not to steal the thread but what would I use on a 91 YJ? the gears listed are for 93 and up
baktie_91YJ is offline
post #5 of 9 Old 11-14-2013, 11:42 AM
bpounds
bpounds's Avatar
Scroll down the Quadratec page. They have the older gears chart.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 9 Old 11-14-2013, 02:04 PM
Dingo1033
Going back to the Quadratec chart: I've got 3.07's on 33's and there isn't a listed speedo gear. What now?
"I may not change the world, but I'll damn sure leave a scar"
Dingo1033 is offline
post #7 of 9 Old 11-14-2013, 02:22 PM
Adams77
Notice that as the tire size goes up one inch the tooth count goes down.
3.07 and 33" should have a 25 tooth gear.
math, it makes cents!
Adams77 is offline
post #8 of 9 Old 11-14-2013, 02:56 PM
jeepguy85
1987 YJ Wrangler
I got the same for the moment. A 26 tooth gear is the smallest I could find. This is what I bought. I talked to the guy that owns the place. Very helpful and gave me exactly what I needed.
http://www.ebay.com/itm/150995815407...84.m1497.l2649
It is installed and runs perfectly. He did say it may require you to trim 1/8" of the end off the cable if it is a mechanical speedo. I did not have to.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #9 of 9 Old 11-14-2013, 03:14 PM
Dingo1033
Thanx man. I was/am never to good at math. Suppose that's why I drove a wrecker for 10yrs
