Speed Sensor diagram? - JeepForum.com
post #1 of 14 Old 01-13-2008, 08:10 PM Thread Starter
Fred007
Does anyone have the wiring diagram for a 2003 NP231J transfer case speed sensor? I have an orange, purple and white with orange stripe coming off the sensor. I assumed these were:
Orange - power
Purple - ground
White w Orange stripe - signal
But that does not appear to be correct. Thanks.
Fred007 is offline
post #2 of 14 Old 01-13-2008, 08:11 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
alldata is super cool
violet is 5v
black is ground
white/orange is signal
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 14 Old 01-13-2008, 08:54 PM Thread Starter
Fred007
Thanks very much. I have a alldatadiy sub, but only for my '90 YJ and my donor motor, not the donor tranny.
Fred007 is offline
post #4 of 14 Old 01-13-2008, 09:04 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
gotcha gotcha... well if you need anything else shoot me a pm or make another post... lots of folks on here have it and are more than happy to share it.
-Erik
post #5 of 14 Old 07-22-2012, 06:21 PM
jt242424
hey i have a 95 yj and i my speedo doesn't work i tried jumping the orange and white from the censor to the cluster and that didn't work my sensor is aligned to the correct position and i bought a new speedo and censor could it maybe be my 5v feed cuz my horn doesn't work either and somebody told me the horn runs off of the same 5v feed any ideas
jt242424 is offline
post #6 of 14 Old 07-22-2012, 06:23 PM
Mark05059
another zombie thread....
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 14 Old 07-22-2012, 06:40 PM
jt242424
I'm new and i dunno what am i doing wrong
jt242424 is offline
post #8 of 14 Old 07-22-2012, 06:48 PM
Que89YJ
JT you resurected a very old thread instead on posting up a new one. The VSS has 3 positions it can be set in in the tcase depending on the gear size. Moving it is called clocking. No, the horn is not related. Check the vss function by putting it in a drill and spinning it with the key on. See if you get a speedo reading. If yoou do then it just needs to be clocked. If you dont post back.
Que89YJ is offline
post #9 of 14 Old 07-22-2012, 06:53 PM
jt242424
thanks i would have never thought of putting a drill onto it ill have to try that tomorrow but i don't understand how if its in the wrong position that it wouldn't work
jt242424 is offline
post #10 of 14 Old 07-23-2012, 06:15 AM
Que89YJ
The gears need to mesh with the drive gear in the tcase to spin the sensor. Since there are different gear ratio's in the axles you need to install a gear that will give you the correct speed depending on that ratio. The gears have a different number of teeth and are physically different sizes because of it. Clocking or moving the sensor meshes the gears. If you look on the side of the tcase it will have numbers to match up where it should be located depending on the number of teeth on the gear. As I said moving it to mesh it to the tcase gear is called clocking it.
Que89YJ is offline
post #11 of 14 Old 11-17-2012, 11:15 AM
TURBevO8
nevermind, should post my question in the TJ tech.
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is online now
post #12 of 14 Old 03-05-2013, 08:51 PM
topherdude30
ok so I have a 1995 YJ and I recently had the instrument cluster out to replace the driver side speaker. when i popped the cluster out and took off the multi pin connector on the tach side i didnt realize that there was a black wire attached to the driver side. now this wire has come loose from whatever it was attached to and remained attached to the speedo. any ideas as to what this connects too? my speedometer and odometer/ tripometer quit working when this wire got disconnected.
topherdude30 is offline
post #13 of 14 Old 03-06-2013, 05:24 AM
Que89YJ
Sounds like the ground for the tach. Here are the pinouts.
Que89YJ is offline
post #14 of 14 Old 03-06-2013, 05:25 AM
Que89YJ
The wiring color might not match but the pinout should.
Que89YJ is offline
Exploded diagram of 32RH 3 speed auto needed UTWeezul TJ Wrangler Technical Forum 3 01-31-2009 02:57 PM
1992 speed speed sensor???? mij3 YJ Wrangler Technical Forum 1 07-21-2008 06:57 PM
Speed sensor SGT Superman TJ Wrangler Technical Forum 7 10-13-2005 07:12 PM
speed sensor JEEPIN_I_AM YJ Wrangler Technical Forum 3 07-10-2003 10:19 PM
Need O2 Sensor Wiring Diagram for 94YJ seanw YJ Wrangler Technical Forum 3 01-06-2003 01:42 PM
