Speaking of A/C's in YJ, can you help? - JeepForum.com
post #1 of 3 Old 10-05-2001, 09:22 AM Thread Starter
OhYeah
Hey friends,
I see from a few posts that a few of you do have A/C in your YJ's. I have it also but all the wiring is tied up under the dash and none of it is hooked up. Can you tell what color the power wire is and where any of the wires are going. I would love to get this working again. I have had the Jeep a year and haven't been able to figure it out.
Or do you know of an installer of aftermarket a/c's, maybe I can get a diagram from them.
Thanks,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #2 of 3 Old 10-07-2001, 08:05 AM
Jeep Chic
Sorry, but I don't have A/C in mine, but I can put this back to the top so someone with the knowledge can help you!
Jeep Chic is offline
post #3 of 3 Old 10-07-2001, 02:28 PM
glm 87 wrangler
Hi.Cant help you on this one but will tell you that,droping the AC unit under the dash was very hard I replaced the heater core on my jeep and worked on the heater fan an the heating system and the Ac was in the way,so I know you may want an easy fix but i would ask around for a auto elect.repair guy or find some one to with knowledge of AC they can usally trace the wires down, there are quite a few.But if you already have the hardware in I would only replace what you need like I did.But to be truthful it is a pain to work on.Sorry!!
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
Speaking of aluminum?? V-8unlimited TJ Wrangler Technical Forum 39 07-02-2009 09:03 PM
Speaking of iPods.... Igottablack1 JK Wrangler Technical Forum 8 03-23-2008 12:55 AM
Speaking of Tranny's Dave R. YJ Wrangler Technical Forum 1 06-09-2007 09:46 AM
Technically Speaking... bigchevyman24 TJ Wrangler Technical Forum 1 04-12-2007 06:02 PM
speaking of the 4x4 light.. evilpsych YJ Wrangler Technical Forum 10 11-04-2001 01:44 AM
