Speaker Wiring - JeepForum.com
post #1 of 6 Old 02-22-2012, 01:53 PM Thread Starter
bootynasty321
Speaker Wiring
OK i bought a new set of speakers for my YJ wrangler. i need to know how to connect the stock wires to the new speakers. the speakers i bought were Polk Audio DB461P. if you could help me out that would be awesome
bootynasty321 is offline
post #2 of 6 Old 02-22-2012, 02:17 PM
scubamc
Connect the positive speaker wire to the positive on connector on the speaker and the negative to the negative. It's pretty simple.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 6 Old 02-22-2012, 02:23 PM
jmmorgan82
2009 JK Wrangler
Cut the connectors off, strip back the wiring, twist together, solder, heat shrink. Once you access the speakers themselves it is maybe a 5 minute job.
jmmorgan82 is offline
post #4 of 6 Old 02-22-2012, 02:27 PM
jbolty
jbolty's Avatar
In the dash? Just run new wires, the less splices the better and the stock harness uses a pretty small size wire.
jbolty is offline
post #5 of 6 Old 02-22-2012, 03:23 PM
YJSteveD
You can buy one of the harness converters from Quadratec, I believe.
If not, it's very easy to splice and connect the wires. I did it with my stock radio (Took out a broken aftermarket and put in a stock) with my stepdad over the weekend. Just strip, twist, put on a stubby rubber wire connector, insert, squeeze. Just make sure everything is connected to the right thing.
YJSteveD is offline
post #6 of 6 Old 02-23-2012, 09:01 AM
VirginJeeper
I'm going to get flamed on this one but I always used to recommend that you put an inline filter on the dash speakers when I did installs. Basically the dash speakers in 4X6 are crap for bass. By limiting the frequency for some mids but mostly highs it will make the speakers crisper and last much longer. You can buy them at Best Buy or other car audio shops. Get some 6X9's for the rear wheel wells and a small amp off craigslist and like jbolty said just run new wires, it will be way less headache. Let me know if I can help
VirginJeeper is offline
TJ Speaker Wiring DouginTN Audio, CB & Ham Radios, GPS, & Electrical 12 03-18-2016 09:10 AM
Speaker Pod Wiring for my 99? SuperWade2 TJ Wrangler Technical Forum 12 10-14-2014 05:34 AM
Speaker Wiring pghohnst YJ Wrangler Technical Forum 7 06-21-2010 03:44 PM
Speaker wiring ridebmx87 TJ Wrangler Technical Forum 1 02-09-2010 09:46 AM
Speaker wiring kandreuk TJ Wrangler Technical Forum 3 08-15-2007 06:31 AM
