spark plugs tell me what? - JeepForum.com
post #1 of 4 Old 06-30-2012, 12:31 PM Thread Starter
bluedaffy
Here are 2 views of my spark plugs. The reason I pulled them is to see if my carb and timing settings agree with the condition of the plugs. I'm looking for that mark on the ground strap that shows if the timing is too far retarded or advanced and I can't really see one. Should it be an obvious color change on the metal?
Also, as you can see there is a lot of carbon on the base of the insulator, what does it mean if there is a lot of carbon in this area but not higher up?
bluedaffy is offline
post #2 of 4 Old 06-30-2012, 12:43 PM
zeus87gn
1987 YJ Wrangler
thats normal ignition to me
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #3 of 4 Old 06-30-2012, 01:39 PM
Jax89Jeeper
Looks like the plug was ran a bit rich, and leaned back out... Maybe still running a tiny bit rich as the carbon build up is a bit high on the ceramic. Try running them another 100 miles or so and check again, the carbon will burn off over time if you are not running rich. This could also be that the plugs are not the proper heat range, a hotter plug will burn off the carbon fater. If the carb is adjusted correctly and you use the stock range plugs, you will have very little soot and a light brown tint on the insulator. Google "plug chop" and look at some photos and do a little reading. As long as the plugs aren't fouling you are in the ballpark and will run decent, you just might hurt gas mileage, worst case it will shorten the life of the cat and fail emissions testing.
Jax89Jeeper is offline
post #4 of 4 Old 06-30-2012, 08:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I agree with zeus87gn. For a carb'd vehicle that is as old as yours they look fine to me also.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
carb , spark plug , timing
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 08:37 PM
93 4.0 spark plugs Robbypfd YJ Wrangler Technical Forum 1 07-04-2010 08:13 AM
New Spark Plugs jeep066 TJ Wrangler Technical Forum 19 04-19-2007 07:20 PM
E3 Spark Plugs cheesycook TJ Wrangler Technical Forum 3 08-24-2006 07:12 AM
Best Spark Plugs for 2.4L; Same as for 6 Cyl? Whytep38 TJ Wrangler Technical Forum 16 10-07-2004 12:36 PM
