Which spark plugs? - JeepForum.com
post #1 of 16 Old 05-24-2013, 05:19 AM Thread Starter
NH2112
Which spark plugs?
I'm finally putting my 4.2l back together, and am looking for the best spark plugs to use. It's got a 4.0l head, it's been Nuttered, and has the large Ford cap & rotor. It had Bosch Platinum FR9HP, but I'd like to make sure I'm getting the hottest spark my ignition system is capable of producing. Are the Bosch good to stay with, should I use the Denso APP985s like my 2000 TJ took, or something else? Thanks.
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
post #2 of 16 Old 05-24-2013, 11:33 AM
jsd1991yj
Im running these e3 spark plugs in my 1991 2.5. I dont have any complaints. I am also running the DUI ignition. http://www.e3sparkplugs.com/
jsd1991yj is offline
post #3 of 16 Old 05-24-2013, 11:35 AM
Siva283
My 95 likes Champian Copper Core. I put bosch platnums in it once because I used them with great results in every other car I have owned but my Jeep absolutly hated them
Ask me how I know...
Siva283 is offline
post #4 of 16 Old 05-24-2013, 03:22 PM
kahanabob
I also run E3's.............likewise, no complaints
kahanabob is offline
post #5 of 16 Old 05-24-2013, 04:26 PM
JBTJ
I like the Autolite Iridium plugs should last about 200k.
JBTJ is offline
post #6 of 16 Old 05-24-2013, 04:28 PM
PA_YJ19
X2 on the champion truck plugs, that's what our 4.0 was made to use an it really likes them. Mine came with Bosch plat 4 or sum crap and switched to the plain old copper champion truck plugs and haven't had an issue since, don't waist it ur money on the expensive ones. All it needs is a spark, our jeep motors don't need ne fancy 3 or 4 pronger to do the trick.
PA_YJ19 is offline
post #7 of 16 Old 05-24-2013, 04:55 PM
dancytron
Consensus is the best thing to run are regular old fashioned copper core plugs like the service manual says.
dancytron is online now
post #8 of 16 Old 05-24-2013, 06:59 PM
JBTJ
True, if you like to replace the plugs every 20k. If not, use a better plug. Nothing wrong with that.
JBTJ is offline
post #9 of 16 Old 05-24-2013, 07:08 PM
Siva283
My gas milage and power drop when I use anything other than copper core. I got almost 50, 000 on mine and they still look new. I habe been throigh a few cap and rotors though and a set of wires. Proper maintenence to keep the engine in good shape will make them last awhile
Sent from my Galaxy S3 using JeepForum
Siva283 is offline
post #10 of 16 Old 05-24-2013, 07:27 PM Thread Starter
NH2112
Oh, I'm gonna have a diesel in it LONG before I hit 200K.
I guess the nice thing is spark plugs are inexpensive so if the ones I choose don't work, it's no more than $25 and 15 minutes to try something else.
Phil
NH2112 is offline
post #11 of 16 Old 10-24-2013, 06:40 PM
supersport126
I'm running a 258 with clearwater 4.0 head and I was running Champion rc-9yc4 because thats what the "Tim Weaver" article called for. Those are now hard to find and Autolite 3923 is a replacement I'm currently running. My question is everytime I look at a stock 4.0 plug the electrode is quite a bit longer then what I have and I'm afraid The piston is gonna hit it. What's the best current plug for a "built" 258/4.0 head?
supersport126 is offline
post #12 of 16 Old 10-30-2013, 01:44 PM
jasonjones21
Bosh platinum +4
jasonjones21 is offline
post #13 of 16 Old 10-30-2013, 01:59 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Champion Coopers, Ive tried a bunch of other plugs in Various different Jeeps and I've come to the conclusion Jeeps do not like anything other then the plain jane Champions.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #14 of 16 Old 10-30-2013, 02:51 PM
Siva283
Quoted for truth
Siva283 is offline
post #15 of 16 Old 10-30-2013, 03:07 PM
bpounds
bpounds's Avatar
When I got this Wrangler, first thing I did was take it to my mechanic and ask him to rebuild the carburetor and generally give it a look over. He said fine, but only if you let me replace those plugs with Champion. I forget what it had in it already. But this guy has been around the 4.2L for a long time.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
